Results 1 to 10 of 17
Thread: Finally Got There
    Default Finally Got There
    ET 9.756
    139.19 mph
    1.414 60'
    After getting the car in the low 10s a few years ago I made the natural goal of going for 9s. A trail of broken parts and bad luck conspired to keep me from getting there. Today I finally broke through the barrier. First run was a 9.81. Next run was my new PB above. I could have pressed on and tried for 9.6 later in the day with even better DA, but the supercharger pulley and hub decided to separate themselves from the shaft. DA was -951 at the time of that pass. A good day at the RCR track rental.
    Dec 2012
    Congratulations! Great 60' makes all the difference.
    Beyond Help tchr49's Avatar
    michigan
    Congratulations!!
    VIP Member Kermit's Avatar
    Va. Beach, VA
    NICE! Congrats on the GRRRR8 time.
    2009 G8 GT MGM.
    Too many projects.
    Detroit, MI
    Nice work!
    2009 Saab 9-3 Combi / 2.0T
    Nov 2011
    Cincinnati,OH
    Very well deserved! Soooo what's next?
    Phillip M.
    Engine: Stock Bottom End
    Cam: BTR IV PD
    Drivetrain: 6L80, Sonnax
    High Compression/Boost/E85
    Friendswood, TX
    WHOAH! That G8 has got “serious steam!”
    Quote Originally Posted by Phil@PnP Tech View Post
    Getting the supercharger hub reconnected to the shaft. After that, I still need to get a 5" intake put on. Then the hunt for a 9.6. Not much else I can do without changing the setup completely.
    Friendswood, TX
    5” intake?
    Dec 2012
    5" diameter cold air intake pipe. Lot's of V guys run them, but there is a debate about how much more power they make over a 4.5" intake. If you don't have a ported blower and a 102 throttle body (which TMH has), you still have a choke point downstream.
