Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Dyno chart after Little Lunati cam swap
    Member gatorayde's Avatar
    May 2016
    widebands at the tailpipe usually read a bit lean, add in an exhaust leak and it gets worse. Weld in an O2 bung near the headers and have peace of mind for $150-200. I agree those track numbers are way off.
    Cams with overlap will always smell rich at idle, regardless of wideband readings (which are usually way off anyways). You can make it a little better by trimming fuel or playing with injector timing but you will have some raw fuel in the exhaust.
    Put a wideband in and verify you're running 12.2-12.5 at WOT and be done. If it's still slow after that it's not your AFR.
    Jan 2019
    Denmark
    Default Dyno chart after Little Lunati cam swap
    Hey guys.
    I was at the tuner shop yesterday for dyno tune.
    The cam timing reading is not moving while the car is on dynopack, even after 4 times of flashing.
    However, its back to work when we pull the car out for street dyno.
    Have any of folks here had this issue before?
    PS. tuning software - ECUtek
