Results 1 to 10 of 10
Thread: what is G8 designation 2009.5 associated with
    Nov 2016
    Default what is G8 designation 2009.5 associated with
    New owner new Member. In the forums I occasionally see some G8's referred to as 2009.5. are they referring to a production date or a significant change in configuration.
    2009 G8 GT mostly stock
    2014 Challenger RT 5.7 Hemi 6 speed manual
    1987 S-10 Truck 283 TPI 700r4 3:42 posi
    1984 S-10 Blazer 87 Iroc 350 roller 700r4 4wd
    1957 Chevy Belair 2 dr hardtop to get an LS and 6 speed
    Beyond Help tchr49's Avatar
    michigan
    Most obvious changes incorporated in the 09.5 were the addition of Bluetooth, cup holder in the center of the lower rear seat cushion, upgraded lifters, 8 quart oil capacity vs. 8.8 in previous years.
    Also, all GXP's are 2009.5's!
    Nov 2016
    Maybe I have a 2009.4 . I have Bluetooth, but no drink holders. Oil capacity I don't know yet
    Quote Originally Posted by muscleparts View Post
    Did you buy it new? Many bought the module to give the older cars BT which may be the case with your car.
    michigan
    Someone correct me if I'm mistaken, but I believe 2009.5's have an L in the VIN??
    My earlier 09 has an L... There is a vin break in the last several digits though. In the last 6 digits, if it's 300000 or higher, it's an 09.5. I think it's 3 anyway.
    michigan
    Knew it was something like that. Mine's in the 3XXXXX and it's an 09.5
    michigan
    Junior Member Roger05's Avatar
    May 2014
    Default MY09.5 when from ?
    I understood all MY09.5 were built from October 2008 (whether Holden domestic, Holden export or HSV).
    HSV Senator SV08 manual MY09.5. LS3 & TR6060. Eibach springs on factory MRC. Walkinshaw (HM) 2.5" catback. Currently being rebuilt.
    Existing: Harrop HTV1900 FDFI super, Harrop OTR, Harrop/ZL1 fuel pump, Harrop (Serck) oil cooler, Comp Cams Rocker Arm Trunnion Upgrade, 160 degree thermo, NGK IZTR5B-11, Powerbond OEM replacement harmo, PSI valve springs, LSM Engineering cam, Trend pushrods, GM AC belt retention kit. Installed & tuned mafless by Sam's Performance, 9psi 586rwhp. Lifters / cam case hardening has failed - noisy.
    Rebuild: Diamond pistons/rings, Callies rods, LS7 lifters, new (same grind) cam, dual valve springs, Powerbond PB1117-SS harmo, new oil pump, new ACL race bearings throughout, bore/hone, heads serviced. Installed & tuned mafless by Sam's Performance - results to come !
