Results 1 to 10 of 11
Thread: A/C belt "fix" problem?
    Member RuLEoF2's Avatar
    Jul 2014
    Default A/C belt "fix" problem?
    Hi all,
    Several months ago, I bought and installed the updated compressor bracket with the added idler pulley that CrazyPaul sells here. Prior to the install, it was obvious that the tensioner had struck the compressor pulley as it was chipped.
    Since the install, everything seemed fine until about a month ago when I started hearing a strange groaning noise when the a/c was running. At first, it was only when the a/c was running, later it started doing it all of time, though not as loud with the a/c off. Following is an audio recording. It's mostly noticeable at higher RPM.
    http://www.mediafire.com/file/ci28wg...se_outside.mp3
    My initial suspicion was the compressor or the compressor pulley bearings so I took the pulley off to inspect the bearings and they seemed fine. Smooth quiet movement and no play. I'm prepared to replace the compressor but it goes without saying that I'd like to eliminate all other potential causes before I do.
    So, my first question is... Has anyone else had problems with the pulleys on the new bracket?
    Secondly, what is the likelihood that either of those pulleys could be causing this noise?
    Thanks.
    Current:
    2016 Chevy SS - "Some Like it Hot" Red Metallic
    Previous:
    2009 G8 GT - Sport Red, Sport Package, Vararam CAI, Borla Exhaust
    Apex, NC
    Quote Originally Posted by RuLEoF2 View Post
    Hi all,
    Thanks.
    I haven't had any problems with the updated part and have probably run it 100k miles. It's always possible it could be bearings in an idler. I'd use a stethoscope (cheap at Harbor Freight) and put the end on each bolt of the idlers if you can get to them...can't remember sitting here in the house if you can access them. Listen while running and that should help pinpoint the sound...also listen to the compressor.
    I'd look at the bearings in the idler pulley myself. It could be the top one, or it could be the lower ones. It's common for them to go bad.
    Nov 2016
    my 2009 G8 GT keeps spitting the belt off the AC seemingly after a hard pass. is updated compressor bracket perhaps a fix
    Jul 2014
    What's the best way to determine if the idler bearings are bad?
    Current:
    Previous:
    They'll usually howl! Get a mechanics stethoscope and start probing!
    Nov 2016
    I don't have a upper and lower. No idler only a tensioner (New)
    2009 G8 GT mostly stock
    2014 Challenger RT 5.7 Hemi 6 speed manual
    1987 S-10 Truck 283 TPI 700r4 3:42 posi
    1984 S-10 Blazer 87 Iroc 350 roller 700r4 4wd
    1957 Chevy Belair 2 dr hardtop to get an LS and 6 speed
    Nov 2016
    Default AC Bracket Fix ??
    Greg at Pace performance is saying that this is the bracket I need
    http://paceperformance.com/i-9892584...r-bracket.html
    This bracket is listed as a 2011 to 2013 Caprice and if Im reading crazypauls posts correctly, this wont work
    Apr 2011
    DFW, TX
    Greg won't steer you wrong. That's the one I installed. CP is no longer in business but I'm sure he'd confirm. Once belt throwing happens it usually starts happening very often. Iirc some have reported damage to crank pulley from a thrown belt. the upgraded pulley piece is considered a good value per dollar purchase.
    09 White Hot G8 GT
    Tuned by Rick Crawford
  10. Likes pir4te liked this post
  11. #10
    Nov 2016
    Thanx Leon, That's what I wanted to hear. Someone who used it successfully and it fit. its in such a bad spot, I didn't want to experiment. Royce
  12. Likes Eli liked this post
