Results 1 to 5 of 5
Thread: Cheap HP/TQ I-M intake heat shields
    Jan 2016
    Ontario Canada
    Default Cheap HP/TQ I-M intake heat shields
    Just wanted to pass this article along. I haven't purchased the product yet but I feel very confident that the results are genuine from reading the article. Also it makes complete sense that lowering intake temps produces power.
    http://www.superchevy.com/how-to/eng...ower-for-less/
    I'm about to order one for my ls6 and l76
    Can't go wrong with those gains for $50-60 usd
    2009 Pontiac G8 GT (Loaded White Hot)
    1991 Nissan 240sx w/built Ls6 (Current Build)
    I read the article. It can't add hp. It can only prevent loss of hp because of heat soak. Looks legit though.
    Jan 2016
    Ontario Canada
    Yea not necessarily adding extra HP but gaining back lost hp. Which is sort of gain. I get what you mean though. Car won't make hp over stock.
    Jul 2011
    Gilbert AZ
    Jeremy at fasterproms has something similar i believe
    09.1 G8 GT, 20x9/10 Red G wheels, magnaflow catback, DT's, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP rear diffuser, BMR strut bushings/cradle inserts, BMR sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel.
    http://i92.photobucket.com/albums/l4...psce2f18b1.jpg
    VIP Member Ben2009GT's Avatar
    Puyallup,Washington
    I have something like this on my intake, can't say it helps or not.
    515 rwhp - 416 Stroker - 2015
    2009 G8 GT PSP, 6.8L Stroker 416ci,CM 228/234 .629/.629 LSA112 +2 Cam,PRC LS3 255CC CNC Heads,Trunion Rocker Upgrade,RCR Intake,FTI Stall 3600-3800,Trans Cooler,B&M flex plate,3.27 Diff LSD,UDP,1 7/8 OBXR LT SS Headers/SS, 3",Borla Mufflers,VCM OTR CAI,LS7 MAF 100mm,Patrick G. ECM/TCM Tune,Koni Shocks/Struts Yellow,Eibach Pro Kit Springs,LCA's w/Whiteline bushings,BMR Sub Frame Connectors,Spohn Tunnel Brace,BMR Fr/Rr Sway Bars,Suspension/Diff Bushings,PMT Rear Trailing Arms/Toe Links,Brembo's Front Brakes,Russell Street Legal Brake Line Braided SS,V8 6.0 Side Badges,GXP Diffuser,G8 Door Sill Plate,Red Shift Knob,SS Rim's,BFGoodrich g-force 255/35/20-285/35/20
