Results 1 to 10 of 11
Thread: G8 Drag Racing - Do you drop your exhaust for the Drags?
    Junior Member auspeed's Avatar
    Feb 2016
    Default G8 Drag Racing - Do you drop your exhaust for the Drags?
    Hi Just wondering what most people do when racing, do you leave the full exhaust system on? or remove rear mufflers or run straight out of the headers?
    Curious to know if the weight savings are worth the potential power loss due to back pressure!
    If I am going for a PB I will drop it after the mid muffler. The whole power loss thing due to loss of back pressure is a myth. You are free to remove anything after the headers and will generally gain some power, not lose it.
    Senior Member Troy TrackBeast's Avatar
    Jun 2012
    Holly Springs, NC
    Weight saving is the main benefit. When going for gold I'd drop but most of the time I'll leave it on and let her eat full weight.
    https://youtu.be/uQhnhQZdsRg
    Rick Crawford Racing Top End, Full Bolt-Ons, and PI 2600 Stall
    Current PB: 11.00 @ 125.91 --60' 1.61
    My YouTube Channel
    Feb 2016
    I guess only 1 way to prove this! I can put on the dyno to test first before I go to the track.....
    Senior Member JessMan's Avatar
    Nov 2015
    Dallas TX
    The whole back pressure thing is from 30 to 40 years ago. You will lose low end torque but you will gain top end Horse power but it is very minimal. It isn't going to be a big difference unless you're still running factory exhaust and then go to open long tubes by removing the factory exhaust. This does help with drag racing because you are in the top end while going down the track. But also you will not gain your full potential if you are tuned for having full exhaust, or you aren't tuned yet at all.
    Pale Horse
    2009 G8 GT Sport Edition
    Mods: Vararam intake, HIDs
    Dec 2013
    phx az
    all the way out the back , ive always laughed and dragged some ass on open header cars at the strip
    Dec 2012
    Another think to look out for is melting the plastic fender liners. When you drop the mufflers, the exhaust exits right at the bend. The one time I did it you could see where the plastic started to melt. That is on a car moving at over 100 mph. If you tried it on a dyno with little air movement you would certainly destroy them. Coincidentally I didn't go any faster with them off, and that was at 450 rwhp and compared to stock GT mufflers.
    Nov 2015
    Dallas TX
    I've always left my exhaust on. I'm not hunting for records or anything like that. I've seen a lot of people jack up their street cars and drop it off but I've always had pretty free flowing exhaust so I've never worried about it.
    Pale Horse
    Feb 2016
    Im getting the view here that its more for weight saving Vs any power or flow advantage....
  10. Likes -Ray- liked this post
  11. #10
    VIP Member Kermit's Avatar
    Va. Beach, VA
    I like to keep everything on just like I would be if I were on the street. The only exception is putting Drag Radials on for better traction. If your going to go for the weight thing, might as well take out the passenger seat too.
    2009 G8 GT MGM.
