Results 1 to 8 of 8
Thread: Maximizer exhaust?
    Jan 2016
    Default Maximizer exhaust?
    Did a search for them and a thread didn't come up. Found the maximizer exhaust on ebay earlier this year but didn't have the funds to buy...now I'm looking for real and I can't come across them but on one site I've never heard of. I believe they are a OBX renamed but I've read pretty good things about them. Wanted to give them a try but can't find. Anybody have any idea what's going on with that?
    merca!!!
    People like them for what they are.
    Don't expect top quality out of them.
    Most people grind and sand the weld sugar out inside and clean up the flanges on the headers. Stuff like that. Some same fitment issues are common.
    You get what you pay for I guess.
    2008 GT-M. PBM, #885
    VIP Member donkeyGT's Avatar
    Dec 2010
    Jenison, MI
    What BuildIt said..IMO if you plan on keeping the car dig deeper in the pocket and get ARH or Kook's.
  4. Likes -Ray- liked this post
  5. #4
    Apr 2015
    Contacted a reseller on eBay and was told they're back ordered. ETA is 30-60 days.
  6. #5
    Member jstclair's Avatar
    Jan 2016
    Colorado
    I finally got around to installing the Maximizer system I bought last year
    Internal welds were fine, flanges looked good.
    Had to trim the lip on the frame, passenger side, the header was hard against it. Just about 1/4 in gives it room to move
    Drivers side two primaries were hard against steering shaft, clearanced that with a BFH
    Hangers for the trans crossmember were in completely incorrect area. I used a couple hose clamps temporary to get down to the exhaust shop and replaced those. Now has the factory rubber.
    I only received 4 bolts, nuts and springs for the header flanges, nothing for the rear connections. I tossed it all and went with new bolts, flange locknuts, and double nuts on top of that. Holding tight after 1500 miles. Also no bolts included for the header to head flanges. I had already bought SS 12 pt locking ones anyhow. Also reused the factory header gaskets as a trial, I have a new set for post LSA install.
    Otherwise bends are good, bungs in proper spot, and butt dyno shows a nice gain over stock. (with Pat G tune)
    1-7/8 primaries into 3 in, steps down to 2-1/2 in just rear of frame support bracket.
  7. #6
    Member Rubberman's Avatar
    Oct 2016
    Evansville, Indiana
    YOu talking axlebacks? I just a set of them last month. Pretty good quality. Its a straight thru design. I get a lot of drone in the 1500-2000 rpm range. its also not as loud as it should be cause i have stock piping but had an X pipe and the resonators removed. Its louder than stock but i dont know what the deal is.
  8. #7
    Junior Member Raffe's Avatar
    Dec 2017
    Trenton, NJ
    What's that maximizer? Like a resonator removal thing or something that amplifies muffler sound?
    I'm just curious what would you need it for if you already have a cool catback there?...
  9. #8
    Jan 2016
    Colorado
    Maximizer/OBX is a header and mid=pipes....
