Results 1 to 10 of 12
Thread: New Trunion Kit On The Market
    Boardman, Ohio
    Default New Trunion Kit On The Market
    GMP-346-1370 Trunion kit w/o bolts - $159.99
    GMP-346-1371 Trunion kit with bolts - $175.99
    GMP-346-1372 Complete LS3 rocker arm set - $329.00
    These new bushing LS trunnion kits for factory LS rockers are designed to increase durability and load capacity without the failure prone to needle bearings. Engineered to provide maximum lubrication to the trunion while also providing maximum load capabilities, the NEW bushing LS trunion UP-grade kits give the LS world peace of mind.
    The proprietary bushing material is fed with an oil channel at the 11 and 1 O’Clock positions of the trunion. This channel constantly feeds oil to the bushing surface ensuring proper lubrication unlike needle bearing trunions the have to rely on oil “finding” it’s way to the needles.
    The greater surface area of the bushing will support 300 times the load of what a needle will due to the fact that only 3 needle on the bottom of the race are carrying the load.
    Also there is NO CHANCE of needle bearings destroying the engine when using much more aggressive cam profiles and a rocker fails.
    Kit includes brand new GM LS (8) straight exhaust & (8) offset intake rocker arms with HD trunions installed and 12.9 Grade rocker arm bolts
    merca!!!
    Nice. I like the bushing better then the bearings.
    2008 GT-M. PBM, #885
    Jun 2012
    McCordsville, IN
    Greg,
    What would be a good after market rocker arm set instead of going with the trunion upgrade kit, that could be use for a street/strip application? I was looking for roller tips on the rocker arms. thank you.
    2009 PBM GXP #741 Black on Black, ARH 1 7/8 stock mufflers, CTS-V wheels, RCR tune.
    Boardman, Ohio
    The Comp Cams 1676-16 would be a good full roller for a LS3 headed engine.
    CCA1676-16 - $419.98 1.8 ratio.
    Cambridge, MA
    I wonder how this trunion kit compares to older ones on the market? I need to look up the one I have installed. It's been awhile.
    Boardman, Ohio
    You most likely have the Comp kit installed.
    I'm not sure how they compare. I take manufacture propaganda for what it is worth
  7. Likes -Ray- liked this post
  8. #7
    Jun 2012
    McCordsville, IN
    Thank you Greg!
  9. #8
    Senior Member landsarmstrong's Avatar
    Jul 2010
    Leesburg Virginia
    Sweet. I guess I can retire my press.
    liquid Red # 804 of the 888s
    HAMMER
    Stock with just a couple of bolt ons
    & a couple of replaced parts to go a
    little faster.
    My cam is 241/253 569/578 106LSA,
    391 ZL rear, 3600 stall,Custom made single plane intake
    Raceing TH400 to get built/1 piece drive shaft/4000 stall
    LIFE IS RACING EVERYTHING ELSE IS WAITING
  10. #9
    Member Supercharged's Avatar
    Jun 2011
    Will the bushing wear out faster than needle bearings.
    Sent from my SM-N900V using Tapatalk
  11. #10
    merca!!!
    Quote Originally Posted by Supercharged View Post
    Yes but the factory ones are bushings. But these ones can be replaced for a "rebuild".
    The reason I like these is because it's hard to fail. The needle bearings only one needs to fail and the rest will follow.
    Just a more reliable setup. But not the best performing.
