Results 1 to 3 of 3
Thread: Timing chain swap
    Nov 2013
    Default Timing chain swap
    I'm swapping out my oil pump as my oil pressure has been a little low. While I'm in there I'm gonna swap out the timing chain and dampener. Will an ls2 chain be a good replacement? I have one on my ls1 currently and it's been good to me so far. My car is stock except headers and I still have DOD with no intentions of doing a cam swap.
    Yes you can use ls2 damp. Be ready to fish parts out of your oil pan.
    Also worth checking / cleaning the little filter that is in the valley cover below the oil pressure sending boss.
    Sent from my LG-D800 using Tapatalk
    There ARE better chains out there! Cloyes comes to mind. Definitely use the LS2 dampener over the L76 or LS3 one.
