Results 1 to 10 of 10
Thread: P0521 Low engine oil presure
    Member wood81's Avatar
    Feb 2011
    Alachua County Florida
    Default P0521 Low engine oil presure
    I got this code the other day. Parked it, took it directly to the shop and they checked the oil pressure mechanically and it's all good. Im replacing the oil pressure sending unit, hopefully that's all it is. Are they notorious for going bad on these cars? Thanks in advance. Car is an 09 G8GT.
    2008 IOM G8GT. Couple Bolt ons 338/349 13.408@107 with a 2.06 60' Sold
    2001 C5Z06 Bolt ons 370/368 Sold
    2009.5 SBM G8GT Exhaust
    US Army Veteran
    Yes, not unusual.
    Feb 2011
    Yes, not unusual.
    Thanks, hopefully that's all it is. No unusual noises from the car and oil pressure is normal. Just DOD doesn't work with the idiot light on.
    US Army Veteran
    One of our club members chased his low pressure for a bit, replacing the sender and then found out the AC Delco filter he'd used was collapsed inside.
    Isn't there a screen behind the sender that can be cleaned? I seem to remember hearing about that.
    Phoenix
    Yes there is a filter below the sensor that should be replaced also.
  6. Thanks Chewy thanked for this post
  7. #6
    Feb 2011
    Turns out the sending unit was bad. Replaced it today.
    US Army Veteran
  8. #7
    Just did mine last weekend too.
  9. #8
    Addicted Member fengstang's Avatar
    Jun 2012
    Houston, Tx
    What part number did yall use
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Blown by Jessika
    Tuned by Pat G
    "Stock" MGM G8
  10. #9
    I got the Borg Warner from O Reilly's. I didn't replace the filter.
  11. #10
    Feb 2011
    Quote Originally Posted by fengstang View Post
    Ill have to go look, I am pretty sure it was the AC delco one from advance.
    US Army Veteran
