Cam install with High miles?
Well my G8 gxp now has 113,000 miles on it now and I have itch for more power. I'm the original owner and has been well maintained. Would it be wise of me to leave it alone or cam it and worry about my motor going soon? I'm looking to make at least 460rwhp to 480rwhp. My car already has supporting mods clutch,headers,exhaust, cold air intake..
113k miles isn't sh!t on an LS series engine - or nearly any quality engine at this point.
Cam away.
I did @100,000
Sent from my SAMSUNG-SM-G870A using Tapatalk
+1 on the cam, my g has 130k on it now, around 20k on a healthy cam from pat g
Thanks for the input I feel much safer about camming my gxp now
Yeah, just replace the timing assembly and you'll have to put in new springs and stuff so I don't see an issue with it. If you pull the trans for a stall, replace the rear main seal. May not hurt to replace the oil pump, but it's by NO means necessary.
Lifters and springs should be replaced while your in there.
Trays, push rods, timing set and rocker upgrade is a good idea as well.
I would inspect the oil pump and seals and make my judgment then.
And its always good to clean the pan and pickup tube as well as the heads when you have it apart.
I made 445whp through a manual transmission with just a mild cam on the 6.0. 480whp is a tall order with just a cam. But you can get close with a manual. Probably best to have it spec'd to your goals.
My car is a m6 so no need for a stall. I did plan on doing springs push rods and timing chain,lifters. Is there any benefit to replacing the roller rockers or a need to change them?
Rocker trunnion upgrade would be a good idea.
Be sure to inspect the cam bearings also. Not sure how well they hold up on the ls3, but 3 of the ls2's ive done all had chunks missing from the cam bearings.
