All gas engine specific oils are going to be low in zinc. Zinc has nothing to do with a 30 second long lifter tick. That points at a mechanical issue. I ran M1 5W30 in my GT with DOD for 55,000 miles and it'd tick for a second or two when cold started, but NEVER longer.
JMO
With 128k and the reliability of the dod garbage being low, I would start looking into dod delete kits rather than zinc content from oil..
16 SSB SS A6
VCM, KOOKS, 3" Solo, RCR MANI & TB, Eibach, VMR
09 PBM G8 GT -
Built By Rick Crawford Racing
404 Stroker / Ported LSA Blower / 2" Headers / Built Trans / Alky Methanol
RCR Heads & Cam / TPIS TB / ATI Balancer / Vaporworks & V Pump
Solo / CTS-V Brembos / BMR / VMR V701 / H&R Coilovers / Holden SSV Conversion
9.89 @ 138.8
09 WH GXP M6 (#1827 of 1829)
Roto-Fab / Solo Mach Shorty
Cheap option would be the upgraded DOD lifters, that's if no damage is done to the cam. If the cam is messed up, might as well DOD delete it and upgrade while you have it apart.
Matt Jones
16 SSB SS A6
09 PBM G8 GT -
9.89 @ 138.8
Lifter tick on start. Oil brand/weight possible fault??
LS lifters fail and score the cam face at reasonably high mileage. I found high ZDDP did prolong smooth noiseless operation by six months same miles in my case, but yeah meantime good idea to start saving for heads-off lifter replacement and in any case might as well get better spec cam to replace old one.
New Delphi AFM lifters and trays are good to 0.320" cam lift and rated to 6600 rpm so now is a good time to re-evaluate valve events with help from an expert.
At same juncture I chose domed relieved forged pistons and rods, doubled down on late 20s AFM cam and very happy with a 500 ft-lb 4000 lb daily driver.
Post Thanks / Like - 0 Thanks, 3 Likes, 0 Dislikes
