Well time to start saving up for a DOD delete kit, cam, oil pump, timing chain, and possibly new valves.
Would you guys say it's worth porting the stock heads?
Pale Horse
2009 G8 GT Sport Edition
Mods: Vararam intake, HIDs
Definitely worth porting the stock heads!
Overall, no. Definitely not the intake with near stock cubes, maybe a bit off the exhaust but depends on cam and purpose.
Sure if you are doing a full race overhaul but be careful what you wish for re efficiency and drivability.
Seems heads like most components do benefit from a bit of tidying but not a major bottleneck vs improving induction velocity and tumble, better valvetrain control and event timing.
Got it. Ill worry about it when I start the tear down and decide then. I definitely want to get the intake manifold and throttle body ported though.
So now my coolant hose popped off on me last night but I fixed it today with a screw type clamp and filled it back up.
And now it just started today I am hearing a pop coming from my passenger front every time I turn right and I'm not absolutely crawling at a low speed. So that's great. What do you guys think? Tie rod, or maybe a bushing?
Pale Horse
Check lower control arm ball joint
Mine got bad enough could see
Wheel move front to back when
I tightened lug nuts
09 BLK G8 GT
2300 Maggie with rear OD cog belt/ 56# injectors / Kennie BAP/ Under drive pulley / TPIS Tune / with E85 has 492 hp to wheels /Moroso deep trans. Pan Camaro Diff. 3.45 : 1
/ 160 Deg. therm. / 1 3/4 Headers with Solo Mach short back /BMR arms rear and diff and cradle bushings
BC coil overs / corvette wheels
Just checked them tonight. They don't look bad and not much movement at all. I think it may be the struts bushings. But everything bushing wise needs to be replaced in the front for sure. Just at first glance you can tell they're old and worn out. Something else to save up for lol.
Back to the lifter situation. I'm looking at the Tick Performance DOD delete kit as I have had a lot of experience with them and I know that I can call them and add whatever else I would need. Cam, oil pump, timing chain etc. But I also saw the New Era brand DOD delete kit. Has anyone had any experience with them? It's a higher price but seems to come with more already in the package deal.
Pale Horse
I've run nothing but Mobil1 5w30 from pretty much day one, across all mods... no lifter tick to be had, DOD or no DOD... if the oil level is good and you're getting the 'tick' one recommendation I can make is get an oil pressure gauge... just because the level is fine doesn't mean you're getting the pressure you need, it may not be low enough pressure to trigger the sensor but it can't hurt to have the gauge to be sure... as for the zinc content myth, this link is excellent reading...
https://540ratblog.wordpress.com/
check out the results for Mobil1 5w30, it's some of the best stuff out there...
Ok cool. I've never been a fan of Mobil 1. My Trans Am didn't like it one bit and always made valve train noise on it, especially on cold starts. As soon as I switched to Castrol GTX it never made a sound after that. Cold or hot.
Pale Horse
