Haas Splitter installed
12036634_10207887187408291_3994145961732507432_n.jpg Haas Flat round splitter installed. Love the style it gives
Vendors
What did you use on your grills for shine?
I use In & Out Spray Adams works so good
2009 Panther Black Metallic "
The Black Rat"
Sounds so
GRRRR8 BECAUSE RACE CAR
Curt here
87 GN bolt ons Alky kit 12.10 @110 on Drs
Did it come with hardware? How many holes do you need to drill.
How did you get rid of the hood gap?
2009 WH GT - no mods yet
1999 Subaru Impreza - de-turboed, awaiting STi swap
Gosh that looks great!! It really does!
Ive got the splitter on the Rat and it really looks GRRRR8 and has a meaner look.
You just have to remember to not pull up to a cement parking block so close
The Black Rat"
Sounds so
Curt here
