Transmission Temps
Hey guys. I just want to check to see if my temps are okay now that I have an aeroforce interceptor gauge. Yesterday was 90+ degree out.. With a lot of city driving, stopping and going, I was seeing temps around 195-200. When on the expressway, I was seeing temps around 190. When it got a little cooler out, around 83 or so, the temps fell to around 180. Generally I was seeing 160ish on a 70-80 degree day. Does that sound about normal or is it high? Just checking to see if I should get a trans cooler or not
Thanks
Jon
2008 NA G8 GT
1/4 mile = 10.93 @ 123
60' = 1.47
DA = 500
ARANGO AUTOMOTIVE & TOWING SERVICES, WEBSTER NY
Interested - subscribed
2009 G8 GT Silver Metalic with Premium Onyx/red - Sunroof - Sport package - Vararam intake - DOD delete - Livernois 2C cam - Kooks Mids 1 7/8" - Corsa cat back - Pedders Xas - triple Gauge - Blue tooth module - VIM
Same for me your about eight
2009.5 g8 gt
kooks LT headers, hi flow cats, x pipe, corsa cat back, vararam CAI, ported TB/intake, slp underdrive pulley, billet catch can, qtp cut outs, kaltech tune, camaro 20s,
350hp...12.60 @ 109.8 mph
Moderator
Those seem to be about the same temps I used to have. A little over a week ago I added a GXP cooler and a deeper pan and now I'm seeing a max of about 140 on the highway with the highest about 165 in stop and go. That was a day in the high 80s. I still have to spend more time monitoring the temps but I definitely seem to have lower temps now. Whether or not the temps before were an issue, I'm not sure, but it definitely got my attention the couple times it crept up over 200 in heavy traffic.
Len
To day was 95* and in town stop and go I was seeing 80* C and on the highway it was 68* C so about 155-175* F.
Shiftless
Do you have a trans cooler?
2008 NA G8 GT
60' = 1.47
DA = 500
LDM
I also added a B&M Tranny cooler with a fan along with the Camaro pan. I've been in the 170 range in Houston where temps have been over 100F!
Older brother had a transmission shop -- constant coaching "heat kills transmissions" ..... these damn things cost too much not to care for them.
Ya I was thinking about getting the GXP Trans cooler
2008 NA G8 GT
60' = 1.47
DA = 500
200 makes me nervous. Towing the camper with the truck, I see 90 degrees over ambient. not towing, I see 65 degrees over ambient. I use that guideline now for all of my cars. If I see over 90 degrees above outside temps, it's time to add a cooler.
My 2013 4x4 DD RAM runs around the same as my car. Last night it was 82ºF ambient and the trans was sitting at 175ºF driving through town. My GXP with a 3200 stall and GXP cooler sits a bit higher than that. I drive it so seldom that it's not really an issue...
