Results 11 to 20 of 29
Thread: New strained power steering sound
    May 2015
    Azusa, CA
    Egads that's some serious noise! Well with the pump off I would say that sound is coming from the Rack. Could it be coming from anywhere else?
    You Tube Vid of it as the Link did not display for me:
    https://youtu.be/YwIg_xJ4B1w
    I should say the louder rubbery creak/snap sound has always been present, but only if I'm turning the wheels off the ground. Under normal conditions, it doesn't make that sound.
    I don't know anywhere else a whine could come from. Anyone know if the steering rack is an at-home job? Or does it require a lift, or whatever else that would be a showstopper for a guy with a garage and normal tools?
    The whine makes me think that there is cavitation or a restriction somewhere. And I can turn the wheel fast or slow and it happens. Are there any valves that can be serviced, or "orifices", or.. I don't even know what. What are my options?
    There is a valve that changes the flow with pressure and rate of turn. but IIRC it's in the rack it self.
    another issue might be your PS fluid cooler. IE clogged up and or not cooling.
    but with it happening only in one direction - then I've got to think it's the rack. and it might be repairable - I know there are shops around that do that and it has an overhaul manual.
    Sep 2014
    S. Florida
    Rubber Sounds like the bushing is going bad. Fluid level seems to be changing a lot, not sure if that has to do with the car being off and not level
    It looks like the rubber washer on top of the strut tower was rubbing on the tower when the weight was off the wheels. I don't know if it is a problem or just an aspect of a dumb design. I am not really worried about the rubber sound for now.
    Jun 2015
    New Jersey
    Check strut bearing plate/mount or siezing ball joint/tie rod ....
    that's what I was about to type. you might have a broken bearing - IE all the balls missing, no grease, etc - and the one rotation allowed in in the rubber bush to metal socket - or between the strut shaft - to inner bushing ferrel.
    either way I'd want to drop the struts out (sadly I think you might have to check both) and see if the mount bush, washers, nut, and bearing on each is shot in the azz.
    next thing - while out - check that the strut shaft will turn free and that the struts aren't damaged in general. (I think this would be easier and cheaper than dropping the rack.
    maybe see if the sound is louder on one side of the car than the other, etc - and start there.
  9. #19
    Jun 2015
    New Jersey
    Hey any update on the noise?
  10. #20
    It hasn't changed and I haven't had a chance to do any more diagnosing. Baby 3 arrived recently and is absorbing a lot of time...
  11. Likes MongosG8 liked this post
