I've got a vibration in the rear somewhere under hard acceleration at fairly low speeds where the load is highest and am trying to figure out what's going on. I've taken the rear suspension mostly apart and found my trailing arm bushings (BMR) on the chassis worn on the left side but not broken. I'm replacing those for good measure but don't think that's the source of the problem. Rick Crawford was helping me look at it last weekend and he could feel the upper control arm bushings were broken so I've removed those and confirmed the break (pics attached - front/back of the right side bushing but both are broken in similar fashion) though I'm not really convinced this is the problem either. Both sides have the rubber split so it's allowing the wheel to move forward more under load than stock would. I have ordered BMR's Delrin bushings for both sides which will hold the UCA much more rigidly. I'll post up results once I get it back together Thursday/Friday. Kyle at BMR has been most helpful as usual and got the parts out today! I should mention that the trailing arms were among the first suspension mods I did probably four years ago now so I am not surprised I have a little wear on those bushings as I have pushed a lot of horsepower for a long time on the car with drag racing and road course events. The BMR parts have been great! Stay tuned!
