Lowering Springs vs Stock Springs for Drag Racing
Hey. Currently I have front and rear Eibach lowering springs in the car. I was thinking that If I replaced the front lowering springs with the stock springs and kept the lowering springs in the rear, that I would have better weight transfer then I do now because the front end would be able to lift more. Does anyone run this set up? What do you guys think about it working better?
Thanks
Jon
2008 NA G8 GT
1/4 mile = 10.93 @ 123
60' = 1.47
DA = 500
ARANGO AUTOMOTIVE & TOWING SERVICES, WEBSTER NY
2008 NA G8 GT
60' = 1.47
DA = 500
- You may not post replies
- You may not edit your posts
Forum Rules
