Page 1 of 9 123 ... LastLast
Results 1 to 10 of 86
Thread: LSA Blower Install (complete parts & install tips)
    Lebanon,Indiana
    Default LSA Blower Install (complete parts & install tips)
    Since several have done this swap and more are looking to do so. Please post if you have done this swap. We can keep all the parts needed and installation tips in 1 thread.I have not done this but this is what I have found so far
    http://g8nation.com/showthread.php?t=42330
    http://g8nation.com/showthread.php?t...ght=LSA+Blower
    Supercharger with bypass - 19257754
    ZL1 Supercharger lid with Cooler Insulator - 12622236 and 12612467
    Intake Manifold Gaskets 19180613 x 2
    3 Bar Map Sensor - 12592525 ***COMES WITH LID***
    IAT Sensor - 12614717 ***COMES WITH LID***
    LSA Water Pump - 19180610 ***NOT REQUIRED FOR GXP or 09.5 GT***
    Crank Pulley (aka balancer) - 12603916
    Idler bracket with both Idler Pulleys - 12606501, 12606031 and 12606032
    Fuel Rail - 12605222
    S/C tensioner bracket with Tensioner - 12606500 and 12622452
    Intake, Tensioner, Idler, and Pulley Bolts - 11588718 x10, 11588742 and 11588749 x 2, 11588727 X 3, and 11900254
    LS3 water pump hose (upper): - 92215927 ***NOT REQUIRED FOR GXP or 09.5 GT***
    Water pump gaskets - 12630223 X2
    Here are some handy reference linkys:
    http://www.ls2.com/forums/showthread...arger-camshaft
    http://www.camaro5.com/forums/showthread.php?t=125123
    LS3-Pushrod-Measurements
    https://www.youtube.com/watch?featur...&v=eKHBaZwIIOw
    Achieving Proper Rocker Arm Geometry
    https://www.youtube.com/watch?featur...&v=Cqx8Cs6O6Vo
    How To Properly Handle Valve Springs
    https://www.youtube.com/watch?featur...&v=x6wIHb1d4Qo
  2. Likes BlackGT5, RacnJsn95 liked this post
  3. #2
    Beyond Help johnbell2's Avatar
    Austin, TX
    cool, subscribed
  4. Likes Old Cop liked this post
  5. #3
    Jan 2015
    I have an excel spread sheet that has 99% of the part numbers and even prices from three different online parts sources if it will help any.
  6. Likes Old Cop liked this post
  7. #4
    Senior Member glanzergtx's Avatar
    Sioux Falls, SD
    Quote Originally Posted by Tweek View Post
    Same here!
    http://forum.grrrr8.net/signaturepics/sigpic7818_3.gif
  8. #5
    Sioux Falls, SD
    Same here! I plan to finish my "how to" with a few more pics to make it a little more clear for people that are doing. Mine is finished. i want the "how to" to be so to say "idiot proof"
  9. #6
    Lebanon,Indiana
    Quote Originally Posted by glanzergtx View Post
    Same here!
    that would be awesome. either post it or PM me and I will add it to the first post
  10. #7
    Lebanon,Indiana
    look forward to seeing the "idiot proof" how to
  11. #8
    Senior Member wastedrubber's Avatar
    Mar 2012
    Metro Detroit
    Good stuff! Based on a quick search, it looks like one should be able to acquire all the parts for the swap for under 3k. Pretty damn inexpensive for forced induction. A cam swap to non DOD stuff is around, what, $600 for the delete kit and a cam? Very reasonable power surge.
    What about a fuel pump or injectors, are they not needed?
  12. #9
    Austin, TX
    good point... LSA or LS9 injectors and ZL1 fuel pump?
  13. #10
    Sep 2009
    VT
    The lsa blower install covers many options ranging from full on squash dual pump, pd cam and Mongo weaponx IC HX in place of crash bar to a blower only with bap, LSA injector and Mustang IC HX mounted under the crash bar with afm still working.
    Can this thread be organized in such a way to keep if from being a run-on? Would it better to have the PN etc in a xls that can be download?
    From my experience, the lsa itself is same as swapping an intake and adding idle/tensioner. The cam work is same as any DoD delete. The challenge is figuring out the IC setup and CAI which much is personal preference.
    Sport /Premium
