Are the G8 wheel bearings the same as the 2010+ Camaros? Or at least interchangeable?
front ones might be - rear ones I suspect aren't. but I don't know.
Both front and rear bearings on the G8 are different from the Camaro
That is what I needed to know. I was hoping the 1le/ZL1 heavy duty bearing would be an upgrade for our cars. Guess not.
how different are they? IE measurement and bolt pattern don't fit - or different part numbers due to vendor change?
The plugs are different I know that much.
2008 GT-M. PBM, #885
camaro bearing are tons cheaper than G8's.... g8's are press in... i dont think camaros are.... it would be a great change to modify everything to be camaro style....
Front bearings are bolt in.
Rears are press in.
Camaro bearings are the same way.
Hmm wonder why the change. Are the ppv parts the same?
PPV and SS rear bearings are the same as the G8.
The front SS bearings are different from the G8 and older PPV, I think because of the move to an aluminum knuckle. It is still different from the Camaro unit.
