Results 1 to 7 of 7
Thread: FS: Zex NOS kit w/all the goodies!!!
    VIP Member The Yeti's Avatar
    Sep 2009
    East Bay Cali
    Default FS: Zex NOS kit w/all the goodies!!!
    SOLD SOLD SOLD
    $800 Buys you my complete Zex Kit shipped within the lower 48, and what a deal it is. Over $1000 worth of parts and accessories shipped to your front door.
    G8 Zex Kit with bottle pressure gauge installed.
    Zex window switch (impossible to find since they don't make them anymore. Only plug and play window switch and only takes minutes to install.)
    If you would prefer I can send the never installed NOS WOT/Window switch pictured instead of the zex window switch that is pictured in the top left
    Zex bottle warmer
    Zex purge kit
    And I will also throw in a never used Nitrous Outlet G8 Cubby Hole switch Panel.
    The zex kit is super easy at to install as you don't have to deal with any drama with wiring and relays and adding components.
    I loved the kit and it was fun beating up on corvettes on my back road expeditions to Mexico. Pull the trigger and get this out of my garage and onto your G8!
    Here it is installed on my car. I hid the lines under cord wraps and located the Zex NMU (soleniods) where the cabin air filter housing is.
    Pat G Tune & DOD cam, Rick C TB, LSA, Ported Heads, Circle D 2600 Stall
    OBX Exhaust, SLP UDP,H&R springs, Koni Shocks
    BP catch can, BMR Bushings/suspension/chassis
    V Brembo's, Slotted/Drilled Rotors, 3.27s Gears
    Bolt ons Street tires
    12.649@107.817 60ft 1.96 Da 700ft
    Heads/Cam pre stall Street tires
    12.16@114.21 60ft 1.75 Da -200
    After Stall
    11.82@115.9 60ft 1.66 DA 400ft
    Zex 125shot
    11.48@124 60ft 1.83 DA 2000ft
    Mar 2014
    Clarksville, TN
    How I hate you, trying so hard to not buy this and piss the wife off
  3. Likes The Yeti liked this post
  4. #3
    Sep 2009
    East Bay Cali
    Quote Originally Posted by mattmid View Post
    I understand completely. Pull the trigger, you wont regret it and your wife will forgive you eventually
    After Stall
    Zex 125shot
  5. #4
    Mar 2014
    Clarksville, TN
    Yeah then I need hp tuners and a tune
  6. #5
    Mar 2014
    Clarksville, TN
    Is it a plate kit?
  7. #6
    Sep 2009
    East Bay Cali
    I used Pat G with his EFI auto cal. After the initial purchase there is no more cost for additional tunes. Since it is a hand held device I don't have to tote a lap top around to switch between tunes, and it takes all of 30 seconds to swap tunes. Plus he is hands down one of the best tuners out there. He has sent me three different nitrous tunes by request, and 15 ECM tunes and 10 TCM tunes overall as I have continued to mod the car.
    There are a lot of options for tuning out there. Some folks have run resister mods to trick the car into pulling timing, others have sprayed with out a tune at all. Pat G is who I would recommend.
    Is it a plate kit?
    This uses the shark nozzle. My VCM intake is too large to fit a plate kit, and frankly I would never run a shot large enough to truly require one.
    After Stall
    Zex 125shot
  8. #7
    Sep 2009
    East Bay Cali
    Sold!!!
    After Stall
    Zex 125shot
