Results 1 to 10 of 10
Thread: B-Pillar Exterior Trim Replacement
    Default B-Pillar Exterior Trim Replacement
    Is the exterior trim (b-pillar, gloss black) replaceable without major surgery? I've tracked this part 92255724 for the front passenger, but I can't find a diagram that leaves me confident it's what I'm looking for.... or a replacement schematic. I managed to nick one of mine when I was replacing the black upper door trim.... and come to think of it, the paint has some defects at the top of one of the others (bubbling slightly).
    Moderator LDM's Avatar
    Mar 2010
    Cape Cod, MA
    Never done it myself, but here's the procedure from the manual.
    Attached Files Attached Files
    Len
    Addicted Member THE Adam V's Avatar
    Jan 2013
    North Canton, Ohio
    Yes it is replacable. I replaced mine. I had the whole door gutted though. I believe you only need to remove the window seal and the door seal to make it happen. 3 Phillips head screws. Make sure you use a magnetic #2 screwdriver or you will be taking that door panel off. Getting the top corner of the seal back on is kind of a pain figuring out how it goes back in. Just take a look at the other side of the vehicle. Not a hard job. Might take total 1 hour.
    2009.1 PSM GT Sport/Premium Package.
    OBX 1 7/8", 3" to 2.5" X-Pipe, SLP Loudmouth, 6k HIDS, VCM OTR
    Rick C Intake and Throttle Body, MM Carbon Fiber Hood, 19x9.5 TSW Nurburgring, Pat G Tuned
    Quote Originally Posted by THE Adam V View Post
    Adam - thanks a lot... out of curiousity... can you remove the interior window trim without removing the door panel? The manual calls for all door trim removal....
    My man! Thanks Len - this reminded me that I had downloaded the manual and didn't check it because I looked at Alldata and came up short...
    Jan 2013
    North Canton, Ohio
    You only need to pull it down. Honestly if my car was home right now I'd go try it and take pics for you but it's currently at the shop again. I am pretty sure I had the panel on. And I pulled down on the top corner of the window trim. Window obviously has to be down for this. Even if you do need to take the panel off that is literally a 10 minute job in itself. It's a handful of Phillips screws and 1 connector for the door lock.
    I did this today...
    You DO need to take the door panel off - but no biggie, and don't forget that pesky screw right under the arm support! The plastic molded inner window trim needs to pop out of place near the b pillar... only up to the corner, enough to pull the vertical window seal loose. You pull the rubber window seal up and out of the door frame near the b-pillar, and peel it up until you can see the top screw of the fascia you're replacing - it doesn't need to come out any more than that. The outer upper window trim (black) will need to move up about 1/2" to give the top lip of the bpillar trim piece (the piece you're replacing) clearance under it. Remove the two screws holding the bpillar trim piece, and then use your hands to create leverage basically "unwrapping" the trim piece lip from around the back of the bpillar. At the same time, work that piece (the piece you're replacing) up and out of the door. Replace the piece, clamp down the outer upper window trim (it snaps back into place with a few retainers), and replace the screws into the fascia. Putting the inner window molded trim and the rubber window seal back in is a bit tough, just take your time. The plastic molded trim goes completely behind the rubber lip of the seal - which is important to remember when it goes back in. Take your time, don't get crazy, push the seal down into the door first, then up into the corner, and then work the plastic molded inner trim into and behind it. Hope this helps someone!
    Member ClarkWGriswald1's Avatar
    Sep 2011
    Cedar Rapids, IA
    Old thread I know, but these b-pillar exterior trim pieces on my car need to be replaced. Where is everyone sourcing these? And are the original ones re-usable after they're removed?
    -WES-
    2009 WH G8 GT
    Beyond Help texn884's Avatar
    Helotes, Texas
    I had a lug not hit mine on the passenger side last month when a wheel stud with a lug not attached hit my windscreen and had a softball size hole in it along with another nut hitting the panel.
    Some stupid ass towing his 50+ year old rv down the road and the hub broke off and the Rat ate them both the stupid mother fucker
    Helotes, Texas
    I did this today...
    Where did you get the replacement piece??
