Results 1 to 2 of 2
Thread: Looking for parts? Check here 1st!
    Default Looking for parts? Check here 1st!
    This is the last 5 years of work by Crazy Paul, moderators and members helping others find parts for their cars.
    This isn't a complete listing of all parts, but the most requested.
    If you are looking for a part, hold down CTRL and press f. Type in your best guess. If that doesn't work, or scanning the thread doesn't come up with your part, then Go Here! and request the part number for the piece you are looking for. Try to be as specific as you can.
    Misc
    key fob with remote start, 92237316
    Steering wheel inserts & related parts
    Black leather auto shifter, 92206987
    Interior
    GM red shifter - 92206988
    GM red wheel - 92217699
    Cabin Air Filter 92184248
    White Plastic Press To Fit Clips 92139070
    Lower Bolster Panel Drivers Side 92193206
    Keys 89027354, Fixed key 89027333, Flip key
    Rubber pad for your key fobs 92206277
    Door weatherstrips
    [url=http://forum.grrrr8.net/showthread.php?t=2637&page=9&p=372022&viewfull=1#p ost372022[Body side sill plates[/url]
    Carpet to floor mat retainers, 92240165
    G8 front lower compartment, 92206138
    Trunk, PANEL. Rear Compartment Trim, 92213099, CLIP; RETAINER (4x reqd) 24405740
    Trunk lid carpet, 92171583, Retainers, 92138253 12 required
    Rear Seat Cushion RETAINER, 24437789
    Dash trim, 92217336 - (888), 92204530 - Micro silver (08-09)
    Glove Box Door Assist Cylinder, 92198445
    Steering Wheel Spoke Cover Kit, (RADO SILVER) 92194422
    Center console rear, Housing, Onyx 08 and 09, 92172603
    RADIO. Radio Receiver, 92228622
    Radio bezel, 2008-2009 - 92207036 - $90.00 (Very Black), 2009 - 92219495 - N/A (1st design Silver), 2009 - 92228612 - $500.00 (2nd design Silver)
    2009 gear surround, Auto Trans, 92235390, Manual Trans, 92225858
    Sun visors
    Center speaker grill, 92218486
    Body Exterior
    Headlamp for your 2009 Pontiac G8 LS3 2EK69. Headlight breakdown
    Left, 92224812
    Right, 92224813
    Cover Headlamp Bulb Access (Low Beam), 92193037
    Cover Headlamp Bulb Access (High Beam), 92193038
    G8 Taillight RH 92202360
    G8 Taillight LH 92202359
    G8 GT Taillight RH 92202362
    G8 GT Taillight LH 92202361
    V6 Taillight, LH, 92202359, RH, 92202360
    Tail light harness, 92215670
    GXP Diffuser 92213320
    Windshield Wiper - Drivers Side - New Style 92219233
    Windshield Wiper - Passenger Side - New Style 92219234
    Wiper arms, The DS arm is 92191436, PS arm is 92191437
    Side markers LH- 92202363, RH- 92202364
    Gas cap is 92232541
    Hood scoops Part number 92221708 is for the left scoop.
    and part number 92213788 is for the right scoop, now supercedes to Part number 9222170
    Roof ditch molding (right) 92172318.Left side is 92172319
    Roof molding insert, 92207446
    Hoodscrew-in adjustables (4x) would each be Part No 90054143
    The 3x fronts are 92161661
    Fender mounted hood rubbers, 92177210
    Hood 92202939
    Hood Insulator, 2202226
    Hood Insulator Retainers, 92139057 (14 req)
    Safety Catch [16](not the part you want [18], its all I can offer) 92202947
    Upper Grille Right 92201781
    Upper Grille Left 92201780
    Fender (Left or Right) 92202891 Various GM sites show different sides
    Fender (Left or Right) 92202890
    Trunk Lid 92218258
    Trunk spoiler 92217652
    Kidney grilles R-92201780 L- 92201781
    Lower grilles, LH - 92205605, RH - 92205606
    Rear fascia, GXP 92213340
    BUMPER/FRONT-FASCIA, GT 92201764
    Fan warning label, 22674722
    GM Performance division emblem, 25927029
    Special Edition Holden SSV (sans Pontiac emblem) 92250666
    Trunk Lip Spoiler yellow clips (5 per car reqd) 25724529
    Left long gutter - 92219093 Window trim
    Right long gutter - 92219092 Window trim
    Left front upper door - 92227428 Window trim
    Right front upper door - 92227429 Window trim
    Left rear upper door - 92227438 Window trim
    Right rear upper door - 92227439 Window trim
    ANTENNA. Radio Antenna, 92202554
    BASE. Radio Antenna, 92218065
    Bumper to fender attachment 92138829
    Headlight wire harness
    Bottom front fascia screws, 92138627 4 req.
    V6 door handles, non painted.
    2 x 92214646
    2 x 92214645
    3 x 92157437
    1 x 92157438
    GT Front fascia, 92250666
    GXP Front fascia, 92213340
    GT fog light housing, 15839896
    RH Mirror Glass, 92214580
    Trunk Latch, 92216374
    Drivetrain
    Rear drive shaft (axle) hub nut and washer. 92139022 - Washer
    Two designs for the nuts now.
    92138989 - 1st design for vins up to 9L191080
    92216821 - 2nd design for vins after 9L191081
    Front Caliper to Knuckle Bolt, 92172963
    Rear caliper-to-knuckle retaining bolts, 92172963
    Front GXP caliper banjo bolts, Pontiac GXP Brembo Caliper Securing Bolt M12x1.75 UHL44mm 92139080
    Pontiac G8 Brake Banjo Bolt 92193458 (I do not know if the GXP banjo bolt is different to normal G8)
    Copper washers, 92138062
    Rubber boot at the slip section of the propeller shaft, 92143595
    ABS Harness, Rear: 92213408 newer number is 92257573 (qty 1), Front: 92211235 (qty 2 required)
    Transmission
    Bracket trans fluid cooler pipe clip, 92193114
    Clip trans fluid cooler pipe, 92220407
    Bell housing to engine bolt, 11515768
    Torque Converter to Flex Plate bolts, 11588468
    Valve, Auto trans vent, 92189630
    6L80 rear planetary 24224747
    Engine V8
    Water Pump, 89018052 ('08 GT)
    LS2 Black Cam Chain Dampener, 12588670
    Cam retaining plate bolts, 11561455, 4 required
    L76 Crankshaft front oil seal, 12608750
    Evaporative Canister Purge Solenoid Tube, 12607115
    Valve cover bolt, 12577215
    G8 GT front Drive Assy.
    Radiator Assembly 92216759, new number 92234040
    Radiator Pipe Outlet Assembly, 92237786
    Clip 92191925
    Drain Assembly, 92191922
    Radiator Cap, 92205634
    radiator support brackets
    Protective cover on the positive battery post, 92190433
    TENSIONER. A/C Compressor Drive/Idler, 12595289
    Valve Stem keepers, 10166345
    INDICATOR. Engine Oil Level, 92068536 (L76)
    TUBE. Engine Oil Level, 92067056 (L76)
    Timing Chain, 12646386
    Exhaust manifold gasket, 12617944
    LS9 head gaskets, (boost), 12622033
    '08:
    Crankshaft..12588612
    Balancer.....12635652
    '09
    Crankshaft...12588612 (Casting number on skirt 81096)
    Crankshaft...12588613 (Casting number on skirt 81224)
    Balancer......12635652
    Balancer......12635649
    '09 6.2
    Crankshaft...12597569
    Exhaust
    Center muffler gasket, 92066863
    Rear muffler gasket, 92066864
    Genuine GM rubber INSULATOR, 22674119
    GT muffler, 92201329 Left 6.0, 92201330 Right 6.0
    Suspension, Wheels, etc
    Lower Control Arm - RH 92183309
    Lower Control Arm - LH 92183310
    Right Hand Tie rod end, 92198274
    Single Silver Cap, 92180805
    Single Chrome Cap, 92180806
    Single Black Cap, 92180807
    Pack of 20 Chrome Caps, 92180802
    4 locknuts and tool set is made in USA and has GM part number 92190654, Locknuts require additional screw-on caps.
    Single black locknut cap, 92182099
    Single silver locknut cap, 92182100
    Single chrome locknut cap, 92182001
    FE2 18mm rear sway bar 92159179
    FE2 20mm rear sway bar 92200024
    FE3 20mm rear sway bar 92200024
    18mm Bushing = Part No 92186962 for sway bars
    20mm Bushing = Part No 92200029 for sway bars
    FE2
    Front
    Left - 92223607 - $102.89
    Right - 92223606 - $102.89
    Rear - 92269782 - $75.00 ea
    FE3
    Front
    Left - 92217535 - $104.76
    Right - 92217536 - $104.76
    Rear - 92269786 - $67.98 ea
    Rear sway bar mounts, 92191934
    BEARING. Rear Wheel, 92171057
    TPMS sensors, 15922396
    Wheel Part Numbers
    18x8 Split Spoke Wheel, 92217685
    18x8 Solid 5 Spoke Wheel, 92217686 or 92217687
    19x8 Solid 5 Spoke Wheel, 92217688
    19x8 GXP wheel, 92212153
    19" sport wheel center cap, 92203235
    18" wheel center cap, 92203234
    GXP Specific
    GXP manual shift knob and boot, 92201936
    GXP Manual 6 speed shifter assembly
    Pontiac GXP rear diffuser, 92213320
    Pontiac GXP rear bumper cover, 92205627
    Pontiac GXP front fascia, 92213340
    Pontiac GXP upper kidney grille (same as G8) 92201780
    Pontiac GXP upper kidney grille (same as G8) 92201781
    Pontiac GXP lower rad grille, 92213351
    Pontiac GXP lower front bumper insert strip, 92224778
    Pontiac GXP foglight bezel, 92213349
    Pontiac GXP foglight bezel, 92213350
    BADGE GXP Decklid/Tailgate, 92213912
    Muffler, 92207803 Left 6.2, 92207802 Right 6.2
    G8 GXP 19 x 8 polished alloy wheels...92212153
    GXP BRAKE PARTS
    DISC ASM - FRT BRAKE, 92213817
    CALIPER ASM - FRT BRAKE - LH, 92221882
    CALIPER ASM - FRT BRAKE - RH 92221883
    HOSE ASM - FRT BRAKE - LH 92226615
    HOSE ASM - FRT BRAKE - RH 92226616
    PAD PACKAGE - FRT BRAKE 89047725
    SEAL KIT - Frt Caliper 89047714
    PIN & SPRING KIT - Frt Caliper 89047711
    BOOT KIT - Frt Caliper 89047722
    BLEED SCREW KIT - Frt Caliper 89047719
    BOLT - Caliper to Knuckle 92139080
    BANJO - Brake Hose to Caliper, 92193458 BOLT
    GXP centre cap = 92203234
    Manual M6 red/onyx shift knob 92184837
    Keyless remote transmitter for GXP M6 w/o remote start 92237318
  2. Thanks Doug Hilliard, TooManyHobbies thanked for this post
    Likes Crazy Paul liked this post
  3. #2
    Bump.
