Nice! I have a modded e-bay can and it has worked well for me. You did a way better job with yours than i did.
One question about the drain. How strong is the spring that holds it closed? It might be designed for positive pressure since it usually resides on the bottom of the oil pan. As long as the spring is strong enough to keep it closed against vacuum your good. Or does it actually lock?
