Results 1 to 10 of 13
Thread: Twin turbo
    VIP Member Blackdevil77's Avatar
    Long Island, New York
    Default Twin turbo
    Ah the executive decision between turbo or supercharger. I was told the turbo charger gives you better gains but you have the benefits of the supercharger right off the line. which will really give you more hp and torque and what will really give you the better 1/4 time? Also, I heard you can't get the twin turbo kit with headers. Is this true? What mod's can't you get with the turbo system that you can get with the super charger? And the biggie, which is easier to install?
    Clarks Summit, Pa.
    You can use shorties with the twin turbo kit.
    Plastic Cuttin' Bad Ass!
    I'd go turbo all day long... Stay out of the boost and MPG will be almost stock...
    Yeah I can't see why the shorties wouldn't work when they are designed to be used with stock exhaust... Right?
    TIGGERATOR MANOFSTEEL69's Avatar
    Berkey, Oh
    There's definately more of a HP gain with the twin turbo. The drive line concerns still scare me away from either this or the supercharger.
    FORMER OWNER 2008 Pontiac G8 GT
    IOM, 20% Tint, 19" Zinik Z27 Sofins, American Racing Header 1 7/8System, Powerbond Underdrive Pulley, 160 Deg. Thermostat,Ported Throttle Body, VARARAM OTR Intake, Livernois Motorsports Tune and Ported Intake. Mobile 1 M1113 Oil Filter, Royal Purple 5W-30, New Era Performance Non DOD 228/240 Cam, Pypes Violators, BMR Trailing Arms and Toe Rods, GXP Front Bumper and Rear Diffuser, Yank 3200 Eibach Pro Series Springs, SJM Line Lock 426 HP and 390 Torque. 1/4 Mile 12.0910 @ 116.53 MPH Coming Someday: Magnacharger.
    LIVERNOIS
    New Era Performance
    http://i354.photobucket.com/albums/r...gger_name2.jpg
    G8erator '02 ws6's Avatar
    White Deer, TX
    Twin turbo will either use manifolds or short headers. blowers are the easier to install due to the turbo kits having blow off valves, wastegates, and oil feed and return lines, down pipes and all other necessary exhaust piping. Twin turbo by far makes more power and combined with a stall and a name brand two step setup (IE a Harlan Two Step) itll take any blower or supercharger off the line as well. As said in previous post, turbos are more economical as well as long as you keep your foot off the pedal.
    Grand Blanc, MI
    Quote Originally Posted by MANOFSTEEL69 View Post
    I wouldn't worry about the trans at least.
    Also, the nice thing with magnacharger is you can purchase a drivetrain warranty from them that covers whatever your factory warranty wont.
    Central Florida
    Quote Originally Posted by 88ls1blazer View Post
    I believe that is only available if your trans is rated for the HP, ours is not. That's the last I heard anyway.
    Administrator Steve's Avatar
    Olympia,WA
    hmm i'm still not sure but tempted to go with a supercharger. peak #'s don't mean much really
    to me - i like the 'under curve' numbers
    -= R.I.P Charlie =-
    http://g8gt.blogspot.com
    Grand Blanc, MI
    Not that I am aware of, the Mustang 5-speed auto is not rated for the HP that they make w/ a maggie, but they still do the warranty.
    I also would NOT be worried about the 6l80e trans, Livernois made 651 rwhp in an 07 vette and it went 17k miles before it let go. The car is street raced every weekend, and ALL of those miles were hard miles
    Central Florida
    You may be right, just seems I remember discussion about it.
    More worried about the driveshaft and diff/axles really.
