Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 132
Thread: Conversion to 8-rib serpentine system
    Apex, NC
    Default Conversion to 8-rib serpentine system
    Since upgrading the blower to the overdrive cog setup along with porting of the blower, heads and going to the LS7 MAF, I've had issues with the 6-rib serpentine belt shredding under harsh conditions such as road course events. After the second trip to VIR where my belt came apart, I decided it was time to go to an 8-rib setup. I did some research and found a couple companies that supplied kits to do this with the major pulleys (balancer, alternator, power steering) but I would still have to find the idlers and purchase the blower pulley. The cost of these kits is roughly $1500-1700 depending on supplier which is kind of high for me! Rick Crawford encouraged me to look for stock pulleys and try to do it myself. I decided to go this route and see what I could do. I did more research than I can remember, looking for pulleys that might work. Typically the inner diameter and width are published but with no information on bearing position front to back. The bottom line is that I wound up working with local auto parts stores to buy pulleys and try them out, return them, try others, return them, try others, etc. until I found the right combination that worked. I had to have a new balancer in any case and found one on e-bay from ATI that was a blemish that they were selling for half-price! They had a couple of them in case anyone else is interested in going this route. The blower pulley was ordered from Magnuson of course and I couldn't find a power steering pulley that worked so I ordered one from Innovators West. All the other parts are off the shelf, some require a washer behind them to get them to the right position and the lower idler had to be machined on the back as did the alternator pulley, but with some work, I saved a ton of money and have a successful 8-rib setup. I won't publish individual prices on the parts to respect forum policy, but the total cost at the end was $630, or a savings of about $900! Below are the parts I used along with a photo of the setup. One more thing: I wanted to use a Gates Fleetrunner Green belt and this was a little dicey. They only make one length that would work for me and it's pretty tough to get on! I have to get the belt on everything except the upper idler via relieving the tension via the tensioner, and, starting with the upper idler off its spindle with the belt under it, use a screwdriver through the idler ID, catch the ID of the spindle and leverage it on with the belt under it (kudos to Rick for figuring out the method!). It's a little tight but works well. I'll look at the possibility of relieving a little material on the tensioner stop to allow the tensioner a little more range at some point.
    Balancer, 8-rib: ATI Super Damper 917345, (stock diameter, for Corvette)
    Lower Idler: (between balancer and alternator) Dayco 89102, smooth, powdered metal, 46mm wide. Machined off ~5mm from the backside (the bearing is offset toward this side), used 1 washer behind.
    Alternator pulley: Ford 208-14000, Wagner W055-25 machined roughly 5mm off the back of the pulley and boss on the alternator
    Power Steering Pulley: Innovators West, part for the Corvette. Had to machine the ID as the press was too high, matched the stock one at 0.667/9 inches.
    Upper idler (smooth, on blower): Dayco 89094, smooth, plastic, 74mm OD
    Blower pulley, 8-rib: Magnuson 2.8in blower pulley
    8-rib tensioner pulley: Dayco 89053, needs one washer behind it.
    Belt, 8-rib, Green Stripe: Gates Fleetrunner K081035HD 104 inch length
    I'll be happy to answer any questions if you have any!
    Last edited by Doug Hilliard; 05-25-2014 at 01:43 PM. Reason: added clarification on which side to machine the lower idler pulley
    Really REALLY cool Doug!
    Apex, NC
    Thanks! It was a bit of a daunting project and took me a few weeks off and on, but I learned a ton and am really happy I did it! Can't wait to get back to VIR and push the car again without fear of the belt coming apart on me!
    VIP Member blue-mayhem's Avatar
    Huntsville, Tx
    Awesome job Doug... I might have to do this too. I've went throught a belt already.
    Nice. Thanks for doing the legwork on this and posting it up.
    Clayton, NC
    Looks like you are going Green!
    Nice job!
    RIP Charlie, The GRRRR8 One
    [SIZE="2"][COLOR="Red"]
    Apex, NC
    One thing I forgot to note: I pulled the power steering pump out and when I went to put it back in, I had a tremendous leak since I didn't replace the copper washer seals at the metal pipe connection. Crazy Paul was tremendously helpful in sending me drawings showing the part I needed to get to replace the washer plus how to do it along with the torque values to tighten it to; thanks CP!
    Apex, NC
    Quote Originally Posted by GXPaycheck View Post
    You got me Brian; probably buying a Prius next!
    ...NOT!
    Default 20 Questions
    I was lucky enough to score a cheap blemish ATI 917345 off of Fleabay today, so it is time for 20 questions with Doug Hilliard:
    1. Any advice for drilling the super damper for the roll pins. Install damper then line up Maggie drilling tool to existing crank holes? Pre drill damper then line up to existing holes on crank?
    2. Lower idler - machined 5 mm off where? Did you do this yourself, or take it to a shop?
    3. Any source for the Wagner W055-25? I found the place in California, but their stock was "In Transit"
    4. Did you remove the alternator to machine the boss?
    5. Innovators West PS Pulley must be manufactured out of gold or they are charging the Corvette tax.
    6. Does the PS pump need to be removed to do the install?
    That is not 20 questions, but I may think of more. Thanks in advance.
    Apex, NC
    Awesome!
    I'm no help on this one; my crank is the CTS-V so it has a key as I recall and didn't need drilling.
    All the machining was done by a friend of mine who is a machinist; the 5mm just comes off the whole pulley on one side so that it clears the block where it rides.
    Sorry; I got the pulley from a local alternator shop who ordered it and put it on for me; problem was they just bolted it on without checking to see if the clearance was right - it wasn't which is why I had to take the boss down.
    I did; I just used a saws-all for this and taped up the alternator to keep the debris out of it. Next time I would probably do it with a grinder but whatever works.
    Yeah, it is pricey!
    I removed mine but I wouldn't recommend it; I think you can do it fine without removing it, and if you do remove it, you'll have to order the washer for the line as it will not seal again and requires a new one. Leave it in place and I think you'll be fine. You might try the pulley on the shaft as is, but I had to have mine opened up per the post as the interference was too much.
    I'm glad to help out and pleased others are benefiting from this thread! You're the second one now!
    Responses in bold.
