Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 132
Thread: Conversion to 8-rib serpentine system
    Apex, NC
    Btw, I've changed to a Gatorback belt as the Green one started making noise and was just too tight. My length might not work for everyone as I think it depends on MY; mine is a 2009. Here's the info:
    Gatorback 18032012 on the belt, P/N 4081045/9PK2655 104.5 inch length
    Do the alternator and PS pulleys just bolt and unbolt, or do you have to use a puller on them?
    Apex, NC
    the alternator pulley is just unbolt - your impact here will be perfect. The PS one requires a puller; I just rented one from AutoZone and it worked well.
    I got the ATI blemish damper yesterday. That is the nicest blemish I have ever seen. The sticker was a little off center, and one small hairline scratch, but other than that it looked perfect. Much nicer than my rusty and paint flaking off stock balancer.
    I have the rest of the pieces on order so in the next couple weeks I will have crank pulley fun time again.
    I think I may paint the PS pulley to make it a little more stockish looking.
    Nov 2011
    Cincinnati,OH
    Still won't fool tech at E2O... they are on to you.
    Phillip M.
    Engine: Stock Bottom End
    Cam: BTR IV PD
    Drivetrain: 6L80, Sonnax
    High Compression/Boost/E85
    Apex, NC
    Mine was the same way; I was really pleased!
    Jun 2012
    Doug, have you seen an increase in boost pressure since putting this together?
    Sent from my HTC M7 using Tapatalk 4
    2009 G8 GT MSM, Sport Pkg
    Rotofab, Magnuson TVS1900 w/3.3", Ported Blower Tub, PB 10% OD 8 rib
    Blitz Ls250 heads pocket ported w/LS3 valves, PSI 1511ML springs, YT 1.85 RR, 7.450 PR, Comp FSL AFM cam
    Kooks 1-7/8 mids, Corsa, ZL1 converter, PPV alt
  9. #19
    Apex, NC
    Quote Originally Posted by Svendingo View Post
    Not from elimination of belt-slip; from all I could tell I didn't ever have slip, the belt would just come apart. I have increased boost to 15 psi though since going to 8-rib and everything is holding together quite nicely so far.
  10. #20
    Default Lower Idle
    All the parts have arrived, so it is time to bug Doug again. For the lower idler (89102) there is a deep side and a shallow side. The 5 mm gets machined off which side? I assume the shallow side since you put a washer behind it. Also the extra belt width is to the front of the engine. Correct me if I am wrong.
