Glad everything is coming along nicely
2008 G8 GT
Rick Crawford Tuned
663/596 Rwhp rwtq for now....
10.87 at 133 1.59 60ft
Good to meet you on Sunday Ray (I had the white GT), car sounded great, didn't realize this was the Vector kit. Good luck at the dyno!
Awesome news, Ray. I can't wait to see and hear it run.
- John Henry Boetcker
Rick Crawford worked on the tune for me. He did a great job considering we had to remote tune with logs. Leaving traction control on for now as it boils the tires going into boost. Thunderstorms today so won't be able to do much to the car.
RPM Transmissions has a track day at Muncie Dragway on Friday so I hope to get a pass in. Probably short shifting at 6k rpms though.
Thanks! I appreciate you understanding and I'll do all I can to make it right and fast. Remotes tunes on a built setup like yours are a challenge to dial in since there was such a big change from the original setup. In most cases I'll try to steer them to someone local but Ray didn't ask for some tune work without a good reason. The new tune has 488 differences from the upload and keep in mind re-mapped tables only count as 1. Boost, injectors, big cam, big motor, stall, high compression, new tune from scatch....whew, I'm sweating just thinking about it typing. There are so many things your try to be safe on but need it close enough so it will drive well to make scanning logs with. I have several turbo tunes but none of them will work on this setup. With a cammed motor that size, a little boost goes a loooong ways and it is very thirsty but picky on timing. Once the tune gets close, the setup will be pretty much limited to sketchy third gear pulls on the street unless you put a 305 M/T ET Street II radial on it. Then you may get to use second gear with power. Just wait until it gets a turbo cam, you wont believe the difference....
Rick was GRRRR8 to work with on my remote tune. He was even available for me when I finally got to go to our track rental at MIR last week and get my 11.3 run. Ray, I'm sure that beast of a car will be one smooth running car when Rick gets done with it. Congrats on breaking new grounds.
2009 G8 GT MGM.
