Results 1 to 10 of 18
Thread: LS3/LS7 card style MAF question
    Senior Member coops09gxp's Avatar
    Aug 2010
    Davenport, IA.
    Default LS3/LS7 card style MAF question
    Hey Greg, thanks again for taking the time on the phone the other day with my lengthy order and also the savings with the grrrr8.net discount!!! I did forget to ask, when doing the swap from the stock LS3 MAF to the card style do I need to swap any wires around? I remember reading about that somewhere but can't find it now. I'm not sure if that was only on the L76 engines or both the L76 and the LS3. Thanks for any help you or anyone else can provide with the question.
    Tony
    09.5 G8 GXP A6, roof, MSM
    Texas Speed LS3 418, PRC heads, Pat G cam, LS9 injectors, Rick Crawford intake, stock TB
    HSRK, Roto-Fab CAI, Kooks LT's, Corsa cat back system, no cats
    Squash Performance fuel system
    BMR trailing arms, toe rods, cradle and diff bushings, subframes, tunnel brace
    GForce anti wheel hop axle set, Camaro 3.45 rear end
    Circle D Specialties 3200 stall
    VMR V710 wheels 19x8.5 front 35 offset, 19x9.5 rear 50 offset
    First National G8 meet, yea, I was there! Car number G42!
    Best ET so far, 11.376 @ 120.25 mph uncorrected, with limited traction
    Tuned by Rick Crawford via remote tune
    G.O.N.E. 2012 & 2013 Best In Class, Fastest in Mod GXP, 2012 Best In Show
    Yes you do... Two wires get swapped... Search ls7 card maf pinout ls3... You're bound to find it. And yeah, Greg is a good guy!!!!
    Aug 2010
    Davenport, IA.
    STL_G8GT, Thanks a ton for that link!!! Judging from that it looks like four wires need swapped though instead of only two. The pink (pin B) and black(pin C) wires for the ground and 12v and also the brown/red (pin D) and brown/white (pin E) wires for the low reference and IAT sensor signal. Is that correct, all four wires need swapped? Thanks again for that link! I noticed you are from Estes Park CO. very jealous, absolutely beautiful place to live!!!
    Tony
    Sep 2012
    Katy, TX
    No you only swap two wires... black and pink
    Quote Originally Posted by coops09gxp View Post
    Tony
    As stated, just black/pink.
    Come visit sometime!!!!
    Boardman, Ohio
    Thanks everyone for getting Coops question answered
    VIP Member Kermit's Avatar
    Va. Beach, VA
    How exactly do you swap out the wires? Just put a jewelers flat tip screwdriver in the smaller slot below the wire you want to remove to "unlock" the wire?
    2009 G8 GT MGM.
    Addicted Member 768MPH's Avatar
    Texas
    Quote Originally Posted by Kermit View Post
    Yes, this.
    I hear people say just swap wires.
    Well...how does one go about that?
    2014 Mustang GT- 6M/Recaros/trackpack
    Little of this, Little of that...
    2009 MGM G8 GT
    SOLD
    Either cut and splice before the plug, or release the pins and swap
