Results 1 to 10 of 11
Thread: 6 Speed Auto Trans - REPAIR Info
    Default 6 Speed Auto Trans - REPAIR Info
    See Also: Thread: 6 Speed Auto Trans - Technical Info
    http://forum.grrrr8.net/showthread.php?t=36512
    REPAIR INFO (On Vehicle)
    Transmission Control Lever Knob Replacement
    http://www.grrrr8.net/crazypaul/Ra.pdf
    Shift Control Linkage Replacement
    http://www.grrrr8.net/crazypaul/Rb.pdf
    Shift Control Linkage Adjustment
    http://www.grrrr8.net/crazypaul/Shif...Adjustment.pdf
    Transmission Control Replacement
    http://www.grrrr8.net/crazypaul/Rc.pdf
    Transmission Fluid Cooler Hose/Pipe Quick-Connect Fitting Disconnection and Connection
    http://www.grrrr8.net/crazypaul/Rd.pdf
    Automatic Transmission Fluid Pressure Test Hole Plug Replacement
    http://www.grrrr8.net/crazypaul/Re.pdf
    Automatic Transmission Electrical Connector Passage Sleeve Replacement
    http://www.grrrr8.net/crazypaul/Rf.pdf
    Automatic Transmission Fluid, Fluid Pan and/or Filter Replacement
    http://www.grrrr8.net/crazypaul/Rg.pdf
    Transmission Mount Inspection
    http://www.grrrr8.net/crazypaul/Rh.pdf
    Transmission Mount Replacement
    http://www.grrrr8.net/crazypaul/Ri.pdf
    Case Extension and Seal Replacement
    http://www.grrrr8.net/crazypaul/Rj.pdf
    Transmission Output Shaft Seal Replacement
    http://www.grrrr8.net/crazypaul/Rk.pdf
    Manual Shift Shaft and Seal Replacement
    http://www.grrrr8.net/crazypaul/Rl.pdf
    Manual Shift Detent Lever and Park Pawl Actuator Replacement
    http://www.grrrr8.net/crazypaul/Rm.pdf
    Control Solenoid Valve and Transmission Control Module Assembly Replacement
    http://www.grrrr8.net/crazypaul/Rn.pdf
    Control Valve Lower Body and Upper Body Replacement
    http://www.grrrr8.net/crazypaul/Ro.pdf
    Input and Output Speed Sensor Replacement
    http://www.grrrr8.net/crazypaul/Rp.pdf
    Transmission Converter Cover Replacement
    http://www.grrrr8.net/crazypaul/Rq.pdf
    Transmission Replacement
    http://www.grrrr8.net/crazypaul/Rr.pdf
    Torque Converter Replacement
    http://www.grrrr8.net/crazypaul/Rs.pdf
    Torque Converter Fluid Seal Replacement
    http://www.grrrr8.net/crazypaul/Rt.pdf
    Automatic Transmission Shift Lock Control Actuator Replacement
    http://www.grrrr8.net/crazypaul/y45.pdf
    Transmission Fluid Cooler Hose/Pipe Replacement
    http://www.grrrr8.net/crazypaul/y46.pdf
    REPAIR INFO (Off Vehicle)
    Torque Converter Removal and Holding Fixture Installation
    http://www.grrrr8.net/crazypaul/y1.pdf
    Case Extension Assembly Removal
    http://www.grrrr8.net/crazypaul/y2.pdf
    Transmission Fluid Pan, Filter and Electrical Connector Passage Sleeve Removal (6L80)
    http://www.grrrr8.net/crazypaul/y3.pdf
    Control Valve Body Assembly Removal
    http://www.grrrr8.net/crazypaul/y4.pdf
    Torque Converter Housing with Fluid Pump Removal
    http://www.grrrr8.net/crazypaul/y5.pdf
    1-2-3-4 and 3-5 Reverse Clutch Assembly and 4-5-6 Clutch Assembly Removal
    http://www.grrrr8.net/crazypaul/y6.pdf
    Center Support, Output Carrier and Output Shaft Removal
    http://www.grrrr8.net/crazypaul/y7.pdf
    Manual Shift Shaft and Parking System Components Overhaul
    http://www.grrrr8.net/crazypaul/y8.pdf
    Manual Shift Shaft Seal Replacement
    http://www.grrrr8.net/crazypaul/y9.pdf
    http://www.grrrr8.net/crazypaul/y10.pdf
    Case Inspection
    http://www.grrrr8.net/crazypaul/y11.pdf
    Output Shaft Disassemble
    http://www.grrrr8.net/crazypaul/y12.pdf
    Output Shaft Assemble
    http://www.grrrr8.net/crazypaul/y13.pdf
    Output Carrier Assembly Overhaul (6L80)
    http://www.grrrr8.net/crazypaul/y14.pdf
    Output Carrier to Output Shaft Assemble
    http://www.grrrr8.net/crazypaul/y15.pdf
    2-6 Clutch Overhaul (6L80)
    http://www.grrrr8.net/crazypaul/y16.pdf
    Low and Reverse Clutch Overhaul
    http://www.grrrr8.net/crazypaul/y17.pdf
    4-5-6 Clutch Dampener Overhaul
    http://www.grrrr8.net/crazypaul/y18.pdf
    4-5-6 Clutch Overhaul (6L80)
    http://www.grrrr8.net/crazypaul/y19.pdf
    4-5-6 Clutch Backing Plate Retaining Ring Measurement
    http://www.grrrr8.net/crazypaul/y20.pdf
    1-2-3-4 and 3-5 Reverse Clutch Overhaul
    http://www.grrrr8.net/crazypaul/y21.pdf
    1-2-3-4 Clutch Backing Plate Retaining Ring Measurement
    http://www.grrrr8.net/crazypaul/y22.pdf
    3-5 Reverse Clutch Backing Plate Retaining Ring Measurement
    http://www.grrrr8.net/crazypaul/y23.pdf
    Torque Converter Housing with Fluid Pump Disassemble
    http://www.grrrr8.net/crazypaul/y24.pdf
    Fluid Pump Cover Cleaning and Inspection (6L80/6L90)
    http://www.grrrr8.net/crazypaul/y25.pdf
    Transmission Fluid Pump Cleaning and Inspection
    http://www.grrrr8.net/crazypaul/y26.pdf
    Torque Converter Housing Cleaning and Inspection
    http://www.grrrr8.net/crazypaul/y27.pdf
    http://www.grrrr8.net/crazypaul/y28.pdf
    Transmission Fluid Cooler Pipe Seal Replacement
    http://www.grrrr8.net/crazypaul/y29.pdf
    Fluid Pump Selective Measurement
    http://www.grrrr8.net/crazypaul/y30.pdf
    Torque Converter Housing with Fluid Pump Assemble
    http://www.grrrr8.net/crazypaul/y31.pdf
    Fluid Pump Cover Installation
    http://www.grrrr8.net/crazypaul/y32.pdf
    Control Valve Body Assembly Disassemble
    http://www.grrrr8.net/crazypaul/y33.pdf
    Control Valve Lower Body Assembly Cleaning and Inspection
    http://www.grrrr8.net/crazypaul/y34.pdf
    Control Valve Upper Body Assembly Cleaning and Inspection
    http://www.grrrr8.net/crazypaul/y35.pdf
    Control Valve Body Assembly Assemble
    http://www.grrrr8.net/crazypaul/y36.pdf
    Center Support, Output Carrier and Output Shaft Installation
    http://www.grrrr8.net/crazypaul/y37.pdf
    1-2-3-4 and 3-5 Reverse Clutch Assembly and 4-5-6 Clutch Assembly Installation
    http://www.grrrr8.net/crazypaul/y38.pdf
    Torque Converter Housing with Fluid Pump Installation
    http://www.grrrr8.net/crazypaul/y39.pdf
    Control Valve Body Assembly Installation
    http://www.grrrr8.net/crazypaul/y40.pdf
    Automatic Transmission Electrical Connector Passage Sleeve Installation
    http://www.grrrr8.net/crazypaul/y41.pdf
    Fluid Filter and Manual Shift Detent Assembly Installation
    http://www.grrrr8.net/crazypaul/y42.pdf
    Transmission Fluid Pan Installation
    http://www.grrrr8.net/crazypaul/y43.pdf
    Torque Converter Installation and Holding Fixture Removal (6L80/6L90)
    http://www.grrrr8.net/crazypaul/y44.pdf
    Holy hell man! Great info thanks!
    Feb 2013
    warren,ohio
    awesome paul thanks
    Senior Member 00 Trans Ram's Avatar
    New Orleans
    Also thought that this might be helpful. Video of a webinar put on by the Automatic Transmission Rebuilders Association (ATRA).
    https://www.youtube.com/watch?v=jXdvWQS-a5E
    New Orleans
    FYI, anytime the TEHCM is removed, you have to replace the Filter Plate.
    Default Transmission parts list.
    AUTOMATIC TRANSMISSION
    5L40-E for V6
    96042712 Detent Plate
    96042860 Extension Housing
    96042861 Extension Housing Gasket
    96041851 Extension Housing Seal
    96042983 Flange
    96042984 Flange
    96042986 Gasket Kit
    8654701 Magnet
    96042963 Main Control Valve Body
    96042540 Neutral Safety Switch
    92191948 Oil Cooler Inlet Hose
    92191949 Oil Cooler Outlet Hose
    96041864 Oil Pan Drain Plug
    96041849 O Ring
    90528145 O Ring
    8677884 Output Shaft Bearing
    96042945 Overhaul Kit
    96042793 Plug
    10478146 Pressure Control Solenoid
    90528145 Seal
    96041866 Shift Control Solenoid
    96041860 Speed Sensor
    96042599 Torque Converter Clutch Solenoid
    96043233 Transmission
    96042971 Transmission Case
    92196977 Transmission Control Unit
    92191917 Transmission Oil Cooler (V6 Radiator Assembly)
    96042545 Transmission Oil Filter
    96043177 Transmission Oil Pan
    96042862 Transmission Oil Pan Gasket
    96042847 Wiring Harness
    5L40-E for V6 ... Converter,Pump, & Clutches
    96042809 Center Support
    96042806 Direct & Reverse Clutch
    96042700 Direct Clutch Hub
    96042807 Forward Clutch Assembly
    96042698 Input Sun Gear Shaft
    96042702 Intermediate Clutch Hub
    96042704 Low Clutch Roller
    96042841 Output shaft
    96042808 Overdrive Clutch Drum
    96042707 Reaction Carrier
    96042705 Thrust Bearing
    96042708 Thrust Bearing
    96042701 Thrust Washer
    96042971 Transmission Oil Pump
    6L80-E for V8
    17803868 Transmission
    Case,Converter & Oil Pan
    24226788 Extension
    24228886 Extension Housing Oil Seal
    24242341 Manual Detent Lever
    24236927 Seal Kit
    24239789 Torque Converter
    24236932 Transmission Oil Filter
    24239528 Transmission Oil Pan
    Clutch Assemblies
    24224724 Center Support Seal Ring
    24238004 Clutch Hub
    24233732 Clutch Hub Thrust Bearing
    24224164 Clutch Hub Thrust Bearing
    24236874 Input Carrier
    24224404 Input Sun Gear
    24224405 Input Sun Gear Bearing
    24239392 Output Shaft
    24224668 Output Shaft Thrust Bearing
    24224188 Thrust Bearing
    24232409 Thrust Washer
    24238905 Turbine Shaft Thrust Bearing
    Control Valve
    24232240 Control Valve Body Lower
    24231442 Control Valve Body Upper
    24242938 Shift Switch Assemby
    24241890 Solenoid Assemby
    24236934 Solenoid Spacer Plate
    24238417 Speed Sensor
    24245720 Valve Body Plate
    Low & Reverse Clutch
    24224175 Backing Plate
    24232457 Center Support
    24224172 Clutch Piston
    24224732 Clutch Spring
    24235460 Friction Plate
    24224733 Retainer Ring
    24224737 Retaining Ring
    24232496 Steel Plate
    1-4 & 3-5 Reverse Clutch
    24224149 Clutch Backing Plate
    24222632 Clutch Backing Plate
    24226393 Clutch Bearing
    24237185 Clutch Housing
    24238700 Clutch Piston
    24238696 Clutch Piston
    24224708 Clutch Piston Seal
    24224707 Clutch Piston Spring
    24235681 Friction Plate
    24224147 Friction Plate
    24238698 Housing
    24240195 Retaining Ring
    24240201 Retaining Ring
    24237851 Seal Kit
    24232498 Steel Plate
    24238701 Steel Plate
    24239828 Waved Plate
    24239615 Waved Plate
    2 - 6 Clutch
    24224171 Backing Plate
    24240221 Friction Plate
    24232994 Retaining Ring
    24235463 Retaining Ring
    24224725 Spring
    24232497 Steel Plate
    24224659 Waved Plate
    4 - 6 Clutch & Turbine Shaft
    24240654 Clutch Backing Plate
    24237556 Clutch Housing
    24224714 Clutch Spring
    24224158 Friction Plate
    24237851 Retainer Plate
    24233406 Retainer Ring Selective
    24224648 Steel Plate
    24219390 Turbine Shaft O - Ring
    24224655 Turbine Shaft Seal Ring
    24224647 Waved Plate
    Cooler & Lines
    92191948 Hose, inlet
    92191949 Hose, outlet
    92190644 Pipe Assembly
    92218904 Pipe Assembly
    92191918 Transmission Oil Cooler (Radiator Assembly)
    Oil Pump & Converter Housing
    24236120 Converter Housing
    24237531 Torque Converter Seal
    24236939 Transmission Oil Pump
    Park Lock Linkage
    24234562 Manual Detent Lever
    24242085 Parking Pawl Actuator
    24225445 Shift Shaft Seal
    Part information contributor: HSV-GTS-300 (Paul)
  8. Likes johnbell2, MongosG8, drumsbh, matts88yj liked this post
  9. #8
    VIP Member MongosG8's Avatar
    Connecticut
    Great info! ..Thanks Ray!
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
  10. #9
    Beyond Help johnbell2's Avatar
    Austin, TX
    thanks... would it be possible to merge this info into the trans repair sticky?
  11. #10
    Merged.
