Results 1 to 10 of 15
Thread: 6 Speed Auto Trans - Technical Info
    Automatic Transmission Controls Schematics
    Figure 1: TCM and Transmission, Power, Ground, Serial Data, Inputs and Outputs
    http://www.grrrr8.net/crazypaul/F1.pdf
    Figure 2: Transmission Internals
    http://www.grrrr8.net/crazypaul/F2.pdf
    Figure 3: Fluid Controls and Speed Sensors
    http://www.grrrr8.net/crazypaul/F3.pdf
    Figure 4: Range and Driver Shift Request Controls
    http://www.grrrr8.net/crazypaul/F4.pdf
    Component Locator
    Disassembled Views
    Figure 1: Case and Associated Parts
    http://www.grrrr8.net/crazypaul/f1.pdf
    Figure 2: Clutch Assemblies and Associated Parts
    http://www.grrrr8.net/crazypaul/f2.pdf
    Figure 3: Torque Converter (w/Fluid Pump) Housing Assembly
    http://www.grrrr8.net/crazypaul/f3.pdf
    Figure 4: Control Body and Valve Assembly fig
    http://www.grrrr8.net/crazypaul/f4.pdf
    Figure 5: Upper Control Valve Body Assembly fig
    http://www.grrrr8.net/crazypaul/f5.pdf
    Figure 6: Lower Control Valve Body Assembly fig
    http://www.grrrr8.net/crazypaul/f6.pdf
    Figure 7: 1-2-3-4 and 3-5 Rev Clutch Assembly
    http://www.grrrr8.net/crazypaul/f7.pdf
    Figure 8: 4-5-6 wTurbine Shaft Clutch Assembly
    http://www.grrrr8.net/crazypaul/f8.pdf
    Figure 9: 2-6 Clutch Assembly fig
    http://www.grrrr8.net/crazypaul/f9.pdf
    Figure 10: Low and Reverse Clutch Assembly
    http://www.grrrr8.net/crazypaul/f10.pdf
    Figure 11: 4-5-6 Clutch Hub Assembly
    http://www.grrrr8.net/crazypaul/f11.pdf
    Figure 12: Output Carrier Assembly fig
    http://www.grrrr8.net/crazypaul/f12.pdf
    Figure 13: Output Shaft Assembly
    http://www.grrrr8.net/crazypaul/f13.pdf
    Figure 14: Park System Components fig
    http://www.grrrr8.net/crazypaul/f14.pdf
    Component Location
    http://www.grrrr8.net/crazypaul/Comp...20Location.pdf
    Bushing, Bearing, and Washer Locations
    http://www.grrrr8.net/crazypaul/Bush...0Locations.pdf
    Seal Locations
    http://www.grrrr8.net/crazypaul/Seal%20Locations.pdf
    Ball Check Valve Locations
    http://www.grrrr8.net/crazypaul/Ball...0Locations.pdf
    Description and Operation
    Definitions and Abbreviations
    http://www.grrrr8.net/crazypaul/Defi...reviations.pdf
    Transmission Identification Information
    http://www.grrrr8.net/crazypaul/Tran...nformation.pdf
    Transmission General Description
    http://www.grrrr8.net/crazypaul/Tran...escription.pdf
    Transmission Component and System Description
    Transmission Adaptive Functions
    http://www.grrrr8.net/crazypaul/Tran...0Functions.pdf
    Transmission Indicators and Messages
    http://www.grrrr8.net/crazypaul/Tran...20Messages.pdf
    Electronic Component Description
    http://www.grrrr8.net/crazypaul/Elec...escription.pdf
    Automatic Transmission Inline 16-Way Connector Description
    http://www.grrrr8.net/crazypaul/Auto...escription.pdf
    Holy Hell Man! Great info thanks!
    #2
    All Motor 11sec club drumsbh's Avatar
    SE MN
    Thanks C.P!
    08' Pontiac G8 GT PBM
    N/A RCR Car
    Jul 2012
    This is great. I was about to purchase the book. Thanks CP.
    Senior Member Jae's Avatar
    What is top mph in first?
    Sent from my DROID RAZR HD using Tapatalk 2
    VIP Member vert's Avatar
    Nov 2008
    Indiana
    Great info and if I keep my G for the long haul I'm sure I will need this.
    Oct 2009
    SOUTH JERSEY
    Great info thanks paul!
