Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 66
Thread: Affordable Fuel Pump Upgrade -- if it is possible
  1. #21
    VIP Member norm8332's Avatar
    Near Buffalo, NY
    You should be able to hit 550 or more with that cam. I was at 500 with my previous cam without spinning the hell out of the SC - 3.2 pulley and no overdrive pulley.
    My Garage
  2. #22
    Member N-V-ME's Avatar
    Jul 2012
    DALLAS
    I have a zl1 fuel pump set up with 60lbs injectors atm going to id850. The pump has held up just fine and the car is 750-800 rwhp. Just adding a bap and bigger injectors for my sense of sanity.
    MSM, M6, Onyx, with sunroof car #119 of the 1829 produced.
    It is also car #5 of 82 GXPs produced in that configuration.
    Kooks Long Tube Header System (1 7/8"x 3") Coating Jet Hot 2000 Degree, Kooks 3" Catted X-pipe , Kooks Axleback, Full Peddlers Suspension System
    Customs ported ls3 heads and stage 2 camshaft, Magnusun Magnacharger Supercharger Kit (TVS 2300), cog 1:1, ROTOFAB COLD AIR INTAKE, ZL1 FUEL PUMP setup with 60lb injectors, Bap ,
    (ID-850coming for new setup), Zr1 clutch, Avant Garde M310 in Gunmetal/ Machined Face 19x8.5(F) and 19x9.5(R) wrapped in BFGoodrich g-Force T/A KDW NT 285/35/19 99Y
    Current set up putting down 640 rwhp/ 592 torque @ 8.5lbs 93oct tune,
    New Set up putting down 710rwhp/740 Torque @ 12.5lbs 93oct tune
    New Toys 417, 8 rib rip pulley system, overdrive cog, GT9 camshaft
  3. #23
    Friendswood, TX
    Quote Originally Posted by N-V-ME View Post
    Holy shit - that is alot of street HP!! You've also got a bigger Maggie.
  4. #24
    Addicted Member TyG8GXP's Avatar
    St. Louis
    You're hitting 750-800rwhp on the stock 376 and Maggie? Or with the 417 motor?
    2009 M6 G8 GXP 710rwhp/742rwtq - Sold
  5. #25
    Addicted Member Blanky's Avatar
    Ft lauderdale FL
    800 rwhp through a auto with a zl1 pump and 60lb injectors... Not
    2009 Pontiac G8 GT
    D1 Procharged
    11.69@119
    Redline
  6. #26
    Feb 2012
    I'm def in the same boat as you, I need to upgrade my pump and injectors. I've been leaning towards the ZL1 pump but i'm not sure If it will be good past 600, I'm currently at 579rwhp with some still left on the table
    Go: Cogged Maggie 2300, Livernois 2c cam
  7. #27
    Friendswood, TX
    So who is the "almighty THOR" related to this ZL1 pump setup & install?
  8. #28
    Addicted Member Semperfire's Avatar
    Jun 2010
    Afghanistan--San Angelo, TX
    ZL1 and a BAP should be good for most power levels. Not the best set up but cheaper than some of the alternatives.
  9. #29
    Sep 2011
    Houston
    ZL1 pump is fine for your power level. I know a couple of the higher powered G8s have them and no issues.
  10. #30
    Friendswood, TX
    Quote Originally Posted by XplicitPerformance View Post
    I recall reading about the gas gauge reading "being off" with this ZL1 pump -- requiring "some adjustments." Was a fix found for that?
    ....or was that the CTS-V pump? .....or is my brain throwing a DTC code?
