Results 1 to 3 of 3
Thread: Door lock cylinder
    Beyond Help It's A G8!'s Avatar
    Next to you!
    Default Door lock cylinder
    Hey Greg what must I do to replace the lock cylinder. Can this part be ordered? And what about the key. If you need pictures Look under, Someone tried, In the lounge section. Thanks
    Boardman, Ohio
    If you need a outside lock cylinder that is bad.
    92212791 - 137.04
    It includes 2 new keys (one flip and one fixed), out side lock cylinder, and ignition lock cylinder.
    Also if you ever need a new key cut from GM you will have to know the new key code as the one for the VIN will not be correct any longer.
    -Greg
    Addicted Member Semperfire's Avatar
    Jun 2010
    Afghanistan--San Angelo, TX
    Greg do you still carry these, I checked the site but it came up no results. looks like I may need one wifes key is sticking in the ignition and I cant troubleshoot the relays some people have had luck with, dealer said its the ignition cylinder that needs replaced.
