You Mods are having too much fun.
RIP Charlie!
2009 MGM G8 GT
Vararam, PaceSetter, Magnaflow, Comp, Pac, Yank
11.95 @ 116.64
UPDATE:
These aftermarket cast heads must be paired up with the cam. my car was fast with them and the Livernois Stage 1 but I just paired them with a PatG spec'd cam.
Its a new world.
What size chamber did you go with? Also, did you go hollow intake valves.
2009.5 G8 GXP White Hot 6M, Heads/Cam/Intake/3.91
515rwhp/477tq SAE Dynojet
7.518@93.48 1.63 60' +1072 DA (1/8 mile)
11.815@118.85 1.83 60' +364 DA (1/4 mile)
CBI Street Cars
DSX Tuning
danlewisracing.com
Yea Richards car whips mine now. Those PRC heads just really like high lift.
The Livernois stage 1 cam just wasn't aggressive enough for those heads, primarily on the lift side of things.
Get it to the track Pee Wee!
New (cheap monthly payment car, lol): '12 Candy Apple Red Mustang GT 5.0 6MT, stock for the time being
**SOLD **
White Hot '09 G8 GT, Pat G tune, Pat G cam (.634"/.608", 223/230, 112 + 2), G8-4-Speed ported & milled heads, "ram air" intake, & ported TB; Reckart 90mm MAF/LS7 card, HSRK, DT headers, Rotofab, Magnaflow CB, H & R springs, stock gears & stock stall, 11.865 @ 120.32 mph, 1.941 sec 60'
Just got a used set of these heads. They came with Manley solid valves and new seals. Any recommendations for this setup? I already have a mild cam, VMS 1.5 cam, it is a high lift med duration setup. What valve springs should I get?
2012 G8 GONE Bracket Champ!
2008 Liquid Red G8 GT-VMS stage 1.5 cam & Pat G tune, Kooks 1 3/4" LTs w/cats to Corsa catback, VCM intake. 427RWHP, 401RWTQ
Eibach springs, FE3, BMR Sways, links & toe rods
Audison Bit-One, JL Audio-500/5, 500/1, ZR800, 10w3v3(x2), Boston Z6, JHP Triple gauges
TSW Indy 500 staggered w/Nitto Invo (285 rear), GXP diffuser, Roto-Fab engine covers
Just a thought,how much more torque can a G8GT drivetrain handle? the reason I ask is that used to build Ford V8 and 302 GMC engines the u joints, axles,trannys suffered as did the rear springs that bottomed on a slam shift.
I never do any 6-2 downshifts
If I was to make a run, I would go into manual mode and then WOT
There are plenty if guys making 430-499rwhp and they don't break transmission or axles
But like most things, it's luck or unluck of the draw
