Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: Yet another Car Won't Start. Need some input.
    Addicted Member Matt82's Avatar
    Mar 2009
    Fort Rucker, AL
    Default Yet another Car Won't Start. Need some input. Update - Car running, new problem
    So, this morning I reflashed my ECM with a few tweaks to the timing that Rick Crawford had suggested for me (since I switched from Mids to Long Tubes), and drove to Wal-Mart for a fund raiser my class was doing. The car was running like normal, I even let it rip through first and second shortly before pulling into the Wal-Mart parking lot. Not a single issue. I got there a little early, so I rolled up the windows or turned on the A/C. A few seconds later the engine shut off. This has never happened before. I cycled the key and tried restarting the car. It cranked but wouldn't manage anything but a sputter here or there. There was no CEL or any other warning lights. Eventually after about a dozen or so tries, the engine wouldn't even turn over. I started to smell something like burnt wiring. Immediately I thought that I had either burnt up the starter motor, or it had just seized from over heating. I had my friend try to give me a jump with his 2012 5.0 (not proud of that) and still nothing. A few hours later we pulled the battery and took it to Auto Zone to have it load tested, and recharged. After 20 minutes and passing a load test we took my battery back and installed it. It started to turn over again and sputtered, then nothing again. I talked the guys there into letting me try a new battery and if that wasn't it they would take it back. New battery installed and no difference. So, I called USAA and had the car towed back to my house. I reflashed it with the tune I had before just to see, and nothing. I had also pulled all the plugs to make sure there wasn't a stuck injector dumping fuel. I've checked all the grounds, and everything looks good. When I cranked the car the voltage went from about 12.4 to as low as 9.3-9.4 volts on my battery. I have heard that the ECM won't let it start with less than 10. If that was the case, then why wouldn't it work on a jump?
    So, starter? Or is there something else I should look at. The car will be sitting for the rest of the night. Thanks for any help you guys an offer.
    RIP Charlie!
    2009 MGM G8 GT
    Vararam, PaceSetter, Magnaflow, Comp, Pac, Yank
    11.95 @ 116.64
    Official Super Member GeoffA's Avatar
    WNY
    Still no codes?
    DON't keep flashing the ecu on a dead battery.
    2009 SBM G8GT (Garage Queen)
    Best Time- 12.640 @ 111.78 1.994 60' w/2.92 gears NOW- 3.45s and fast!
    click on any colored words in sig for more detail
    8222 miles and resting 8/16/2020
    Apr 2009
    My starter went out when Rick had my car a few months ago. It kept blowing fuses. I told him to go to Advance or Autozone and get a starter for a 2500 Silverado (6.0ltr) and it worked fine. Sounds different and slower to start, but it's been fine.
    Performance mods: Roto-Fab CAI, Rick Crawford Ported Intake Manifold, Rick Crawford head work Can, Formato Ported Throttle Body, Kooks 1 7/8 LT's, Solo catted Mach Balance exhaust, Circle D 258MM 2800 Stall, 226/230 .598/.608 113+1 cam, BMR complete bushing kit, BMR Toe Rods, BMR Trailing Arms, Pedders caster, camber & toe adjustment kits, BMR Sway Bars, BMR Sway Bar End Links, Camaro Brembo's w/custom powder coating. 11.90@116.58 1.78 60' on 20" All Season Tires
    Mar 2009
    Fort Rucker, AL
    Quote Originally Posted by GeoffA View Post
    Still no codes?
    Thats the thing, unless I turn the key to start I have over 12 volts. I just wanted to make sure the tune wasn't the problem.
    RIP Charlie!
    2009 MGM G8 GT
    11.95 @ 116.64
    Mar 2009
    Fort Rucker, AL
    Quote Originally Posted by Virus View Post
    Any idea what year silverado?
    RIP Charlie!
    2009 MGM G8 GT
    11.95 @ 116.64
    Apr 2009
    Quote Originally Posted by Matt82 View Post
    I think it was an 03-04 Chevy 2500 6.0ltr. It's a heavy duty starter and larger than stock. Barely fit, but it worked like a champ. The 09.5 has an entirely different plug so Rick had to cut my stock plug off. It works fine with the 08-09. Make sure to check with Advance's online coupon if that's where your going. You can save a ton by ordering online for in store pickup.
    LOST BUT NEVER FORGOTTEN GRRRR8's Avatar
    Sugar Land Texas
    You need to make sure you don't have anything touching the headers near the starter or the positive cable on the drivers side that is very close to the header.
    2008 Liquid Red Pontiac G8 Sport/Premium - Adams Polishes - American Racing Headers - ARP - BMR Fabrication - Circle D Specialties - COMP Cams - Crazy Paul - Dynojet - Earl's - Flowmaster - Fuel Air Spark Technology - G2 - GFORCE 1320 - Greg Weld - HP Tuners - JBA - Lingenfelter - Maverick Man Carbon - Metco Motorsports Solutions - Mickey Thompson - M&H - Mike Norris Motorsports - NGK - Pace Performance - Pedders USA - Powerbond - PSI - Russell - SBX Performance - SJM Manufacturing - SPOHN Performance - Tony Mamo - Vararam - Vector Motorsports - Wretched Motorsports - 470 RWHP 427 TQ - Engine Tune By Patrick G
    Mar 2009
    Fort Rucker, AL
    Quote Originally Posted by GRRRR8 View Post
    I'll check those in the morning. I'm out decompressing at the moment.
    RIP Charlie!
    2009 MGM G8 GT
    11.95 @ 116.64
    Super Stock! I12XLR8's Avatar
    Jan 2011
    ON, CAN
    Fail to start sounds like the fuel pump. Do you hear it buzzing when you turn the key to the run position?
    R.I.P. Charlie. We are all here because of you
    "I have dreamed a dream, and now that dream has gone from me" - Morpheus of the Nebuchadnezzar, and Grant of I12XLR8.
    'Luskville is a cool experience, Calabogie is incredible, Mosport is life altering'
    Mar 2009
    Fort Rucker, AL
    Yeah, it seems like its getting fuel. The motor won't turn over now. If it does and still won't start, I will probably pull a fuel line and crank it to make sure the pump is working.
    RIP Charlie!
    2009 MGM G8 GT
    11.95 @ 116.64
Tags for this Thread
