ZiM I never noticed the level sendors were at different heights. Nice find.
Yes, and it seems because of this difference, once the tank is full, the float reaches the top before the arm is reading full... If that makes sense.... So, it may seem that there could be two fixes, a resister that compensates the difference, or bottom out the float, so that it reads full correctly, but will not read empty when it's too late? I'll leave that up to you and Carl to figure out...lol. Honestly, I think the best fix would be a resister..... Or, now that I just thought of it, cutting the float arm a bit...?...???
That doesn't seem correct.
If you bend the arm to the correct lower level it shouln't hit the top of the tank anymore and read the correct full level.
I just filled up today. Put in almost 16 gallons and the low fuel light just come on. I had 3 spare gallons in the tank still.
The fuel gauge was just touching the full bar on the gauge.
Edit:
Now I'm interested in comparing the actual V level sender to the G8 sender. The problem is they are on backorder an no dealer near me has one.
There are a few in MI, IN, FL, TX, and 1 in NY
I bent my rod when I installed my CTS-V pump. I measured the stock height and then bent it to be the same height when on the CTS-V pump. I also rotated the pump after cutting the tab. It is fairly close, but not perfect. The adjustment may have gotten buggered up a bit when trying to shoehorn the pump in though. It is not off enough for me to worry about pulling things apart again to tweak it some more.
Greg, can you order two CTSv- float assemby....I think it may work on our cars and if that's the case, i want to be the first to install without waiting...lol
the main problem is the height, and length of float arm, the float hit's the top of the tank, before the sending unit reads full, thus preventing correct reading....you can rotate the hat in tank till you're blue in the face, it just wont fix the problem, and if you bend the float too far down, you'll run out of fuel before it reads empty....
I'm willing to spend the cash, but at that price would prefer to be sure the arm is shorter....can you check?
