Results 1 to 8 of 8
Thread: Differential gear oil change
    Oct 2009
    SOUTH JERSEY
    Default Differential gear oil change
    After much research on various forums, including the Holden forums, it has been determined that the "best" is actually the "only" lube that can be used on our G8's with the stock non-camaro rear. Apparently only the G8 and the Land Rover "E" or Electronic Differential uses this special Carbon Modified gear lube. It is 75w-85 fully synthetic gear lube with special modifiers/additives for our carbon coated parts. The fluid is made by Castrol. It is called: Castrol SAF Carbon Mod Plus, it does not cross to any other type fluid or brand. The diff has carbon clutch discs. The castrol lube is is designed for our type of diff specifically. Land Rover part number is LRN #500070 and is roughly 60 bucks a qt. GM part number is # 92184900. Locally it was 40 bucks a qt from my Pontiac/GM/Buick dealer. It came in a new bottle exp dated to 2/14 and mentions to be used for carbon coated rears and is back compatible (though expensive). I asked for a discount and he gave me 15% off just for the asking! Unfortunately it does require two bottles because it uses just 3-6 oz of the 2nd bottle.
    I have78,000 hard miles on my car.
    When mine came out it was BLACK AS PITCH, and oddly much thicker then what went in, which BTW was nearly clear like apple juice, and much thinner then what came out. I plan on getting another bottle and replacing this fluid again in like 3 months, I will essentially use this change as a flush since the out going lube was so dark black. SOTP feeling was that it was very quiet, did not realize my rear was making any noise until it was gone, a real smooth feeling, like driving on silk. And it seems I really did get a bit more mpg, though complete testing is continuing. I figure 1/3 to .5 of a mpg. I do reccomend a change of the rear lube around 50,000 miles or so. My mechanic took roughly an hour to do in the driveway.
    Member 99ssragtop's Avatar
    Apr 2012
    pitch black,
    OCD DIYer Eidolon's Avatar
    Raleigh, NC
    Quote Originally Posted by 99ssragtop View Post
    pitch black,
    Vin Diesel, what?
    Good to hear the change went well. It'd take even less time, but the stupid rear exhaust piping is in the way of the drain plug. *grumbles*
    Sent from my Galaxy Nexus using Tapatalk 2
    Oct 2009
    SOUTH JERSEY
    My exhaust is not stock, and he did not mention any hardship because of the pipes. I will ask him.
    Raleigh, NC
    Quote Originally Posted by AVIDMOTION View Post
    May have made it easier. On my car, I can remove one of the American Racing Headers midsection pipes to get to the diff. Then again, he may also have TOOLS. At least more tools than I do.
    I had the same findings.
    Increase of MPG - I didn't really notice a reduction in noise - and better diff action with pushed hard.
    meanwhile I spent more time filling the diff than I did getting to stuff. damned suction gun wouldn't hold enough and I had a lot of loss.
    next time I will used a funnel and a hose and use a 3'rd hand.
    Also I used about a quart and a half filling to the edge of the fill port - IE where you could feel the fluid with your pinky finger
    Jul 2012
    Airdrie Alberta
    In Canada, my dealer had to special order from the US.. I used Royal Purple, no issues, gone about 7,000 miles, still does posi burnous, and no noise. Guess if it blows, I will get a Camaro 3.45 Diff...
    Oct 2009
    SOUTH JERSEY
    There was a lot of various forum activity related to this topic, most of which pointed to stay with the stock stuff, nothing was really an improvement and alot of weird things happened with changing from the stock special recipe, I did not wish to tempt fate with my luck, so stock lube for me....
