I've picked an off the shelf Comp Cam using link bars.
It's a comp cam off the shelf grind, but it can be changed up a little. I'm going to run the cam through Mike Norris.
113 LSA +4? probably.
Duration at .050" lift. Intake 235, exhaust 251.
Lift .621" intake, .624" exhaust.
Going with link bars, but concerned about the manufacturers comments. Most say up to 6500 rpm, but I should be able to red line @7000 with no problems. WOT shifting at 6800.
Comments?
