I hate reading threads like this, makes me paranoid!
Good luck Ray!
[COLOR="#000000"]
[B][COLOR="#000000"]
Damn, Ray. Now I'm paranoid!
HSV E3 Bumper and Fenders
VMS DoD-Delete with heads
TVS1900
RCR TB
Kooks 1 7/8 Mids+SOLO Mach
ZL1 Brakes
Roto-Fab
[COLOR="#000000"]
Is there .020" lash? Or can you just push the plunger down .020"? I have plunger get stuck and just ran a longer pushrod for a little bit. BUT if you are flat-spotting a roller, it will break and make a mess if you let it go too long. Possibly trash the block. Try a single longer pushrod and see if you can push the plunger down further when putting the rocker back on. Then either run it for a minute or just take it back off after a few minutes and see if the plunger either stays stuck or releases. This may help determine if the lifter roller is worn down or it is just a stuck plunger. The stuck plunger can be "un-stuck" with just using a longer pushrod for a few miles. You can buy single pushrods for a couple bucks.
IIRC, Ray's stockers are about .020 longer...
No. That was before the C-D transmission and was run on 20" all-season tires mounted on wheels that added up to 20 pounds per wheel heavier than my current VMRs and DW Contis. It was run right off the highway (no cool down) on street pressures and it was the only run made before the track closed for the day. There was more to be had but it was all the time there was.
TVS1900
RCR TB
ZL1 Brakes
Roto-Fab
[COLOR="#000000"]
Rick, I didn't take a feeler gauge to the rocker, but I can put it back on and check it. The previous lifter flat spotted. Ground around .250: off the roller, and part of the side of the roller up to the pin.
I'll see if the lifter is stuck/collapsed by pushing down on the push rod. Doesn't matter, I think the engine is coming out.
