I removed the prices for Deals 19 & 20 from my website a long time ago because the shipping costs became ridiculous. The only reason was because the box containing long gutter trims was around 8 feet long. Airfreight was charged on volume occupied and not actual weight of the box.
http://members.iinet.net.au/~pjsadle...es/Page430.htm
So with many of you now looking to coat your chrome door trims black instead, here's some packages to assist.
DEAL 19A
The trim clips on the long curved gutter trims often break on removal from the car. You have 14 white clips, 6 yellow (or pointy white clips), and 2 green clips per car.
Deal 19A is a package of replacement clips containing:
14 new white clips.
6 new yellow (or pointy white) clips.
2 new green clips.
Total shipped price US$40
ETA approx 10 days by Airmail.
DEAL 19B
The trim clips on your 4 straight chrome upper door trims may also break on removal from the car. There are a total of 6 clips spread over the 4 straight trims, with each clip different to each other. You cannot rob a clip from one position to put in another position on the car.
Replacement clips are not available from GM or Holden for any of the 4 chrome upper door trims, which means if you break a clip you will need to buy a complete new chrome strip (approx US$75ea). If you break a clip while installing a freshly coated upper door trim you'll still need to buy a new strip just to get a new clip.
Solution
I can supply a package containing 4 new Holden black straight upper door trims which come with all new clips pre-installed. You can match this black to the required black coating for your 2 long curved gutter trims. Also provided will be all 22 new replacement clips for the long curved gutter trims.
(You can afford to break every clip removing your gutter trims).
Deal 19B is a package containing:
4 new Holden black straight upper door trim pieces.
14 new white clips.
2 new green clips.
Total shipped price US$215
See Post#7 for a 2x Deal19B deal shipped to a single address.
