Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: ZL1 is now pushing E85
    Jan 2012
    North Las Vegas
    Default ZL1 is now pushing E85
    Mods: ProCharger P1-SC 9psi, AFR long tubes, stock mid/catback exhaust.
    Only change between the two runs was the tune for E85. THAT IS IT!
    I have a cutout being installed once we raise the car off the ground an inch or so. This will add quite a bit of power since my stock exhaust is so restrictive.
    Dyno Tuned by Sam at Fairway Chevy Speed Shop
    2008 ProCharged/Pedders G8 - 633/525
    P1-SC, 10 psi, E85, LS3 heads, Buford cam, CTS-V brakes, Forgeline 3 piece wheels, Pedders Coilovers/bushings/sways, tons and tons of extras
    LSXTV Story on my G8
    600+HP G8 for sale
    VIP Member vert's Avatar
    Nov 2008
    Indiana
    If I am reading that right, you picked up 62HP going to E 85. Nice!!!
    Jan 2012
    North Las Vegas
    Yes sir, 62hp, 47tq... I think it made more under the curve too.
    I am also set up on a switch to go to 91 octane if I can't find E85.
    best of both worlds.
    600+HP G8 for sale
    Sep 2011
    Houston
    was this on stock cam/DOD?
    Jan 2012
    Wow. Ive heard plenty of boosted guys running it with good results.
    Jan 2012
    North Las Vegas
    Yes it was.
    600+HP G8 for sale
    Jan 2012
    North Las Vegas
    Quote Originally Posted by MeanGreenZ71 View Post
    Correct. I was the first to prove it functions properly and the first to prove it works with E85. Well, Sam my tuner /builder was but you get the idea.
    600+HP G8 for sale
    Jan 2012
    North Las Vegas
    Time to figure out a cam choice
    600+HP G8 for sale
    Lebanon,Indiana
    nice gains with E85, most of the guys around here run E85
    clark, mo
    Man, thats impressive. Did you make any changes to fuel system? I've been kicking it around since I can get e85 now in my area. I'm running a 1900 maggie with stock dod setup, I need to find someone in the area that can tune it for e85, I've got the hp tuners, but just need someone to do the intial tune. Are using another fuel tank for your e85?
