Results 1 to 4 of 4
Thread: Single use bolts
    Default Single use bolts
    There's a massive amount of mis-understanding on this Forum surrounding bolts which GM instructions specify to discard after a single use.
    There are 2 different reasons why GM will call for a bolt to be discarded.
    1) The bolt contains a single use thread sealant (usually a dry powdery blue substance on the threads). In GM speak "Important: Bolts with micro-encapsulated thread sealant must be discarded after removal."
    OR
    2) The bolt is designed as a Torque to Yield (TTY) bolt, which means the bolt threads are designed to permanently deform at the final specified torque setting.....which prevents the bolt from backing out in service.
    Note: TTY bolts may also have thread locking compound on them from factory, eg: head bolts and crank balancer bolt.
    How to tell which bolts you can actually re-use.
    1) Check the GM specified torque setting for the bolt in question. If there is only 1 torque figure given eg: 30 N·m (23 lb ft). Then if there is any blue goo remaining on the thread you can clean the bolt thread, apply new thread locker/thread sealant and re-use that bolt.
    [GM doesn't recommend recyling bolts in this fashion, but there is no real reason you cannot if you wish.]
    Which bolts are actually TTY and cannot be re-used.
    2) Bolts with an initial torque figure + a stretch (angular measurement).
    In the example below the final application of the 150 degrees is the TTY process......the bolt threads are being stretched permanently on purpose.
    Example:
    Tighten
    • Tighten the bolt to 100 N·m (74 lb ft).
    • Tighten the crankshaft balancer to crankshaft retaining bolt an additional 150 degrees
    Central Florida
    Good explanation of an important point. Stuck.
    Beyond Help ULTRA Z's Avatar
    Philadelphia, MS
    Very Good Info
    2009 SBM G8 GT
    2007 Suzuki GSX-R 1000
    And another important point.
    The torque values given by GM in their instructions always refer to stock GM bolt materials.
    So if you are replacing a GM bolt with an aftermarket bolt then the GM torque values go out the window.
    Case in point....replacing a stock GM TTY crank balancer bolt with an ARP (234-2503) multiple use bolt.
    For an ARP bolt use the ARP provided torque value eg: balancer bolt =235 ft/lbs
    {Note there is no additional angular twist for ARP (non-TTY) bolts}
    Believe it or not you can actually break an ARP bolt by trying to wrongly apply the much lower GM specified torque + an angular twist (for stock GM bolts). The twist part will get you every time if the bolt is not designed to yield.
