Results 1 to 10 of 15
Thread: time it takes to install underdrive pulley?
    Dec 2011
    Albany NY
    Red face time it takes to install underdrive pulley?
    just got off the phone with my local speed shop and thay told me that it will take them 5 1/2 hours to replace the underdrive pulley. why does that not sound right to me? they said that if it is pressed on they will have to take the rad. out and put a puller on it. can someone shead some light on the process im replaceing the udp please?
    Beyond Help gr8lover's Avatar
    SE Michigan
    I was messing around (not in a hurry) and got mine off and on in under 4 hours..... but it is my least like job so far on the car..... it is a pain in the butt ... at least it was for me....
    I removed from bumper, fan, radiator..... not sure if you need front bumper off but I was doing it when I was doing my maggie... ?(removing udp to put normal one back one...)...
    not sure you could get it off without a puller....
    I know some shops that dont like doing this job either and charge more for it....
    I would just get some quotes from a couple places and see how it compares... if you dont want to do yourself....
    VIP Member 98aggie's Avatar
    Sep 2009
    Mission Valley, Tx
    Takes me about 30 mins
    Dec 2011
    Albany NY
    takes you 30 mins? you dont take the rad. out or anything? i dont see it getting dont in 30 mins.
    Lake Jackson, Tx
    Quote Originally Posted by 98aggie View Post
    this. (Since Kurt takes 30mins, it would take the better than average DIYer 1 hour).
    with a three jawed puller, there is no need to pull the radiator. The fans may need to come out (10 minute exercise), the air intake tract comes off first, belt off, AC belt off, back the stock bolt off (impact it loose), place the puller on, start removing the pulley. Once it gets started, back the stock bolt out more and go at the puller some more. eventually, it will come off. Install is easier, and requires a longer than stock bolt to get it started. I also placed mine in the oven at 200 degrees for a bit to heat it up and make the install easier.
    Sep 2009
    Mission Valley, Tx
    I can pull and install with rad and fans installed. Just have to pull the belts and starter. Torque from underneath the car while holding the flywheel. Use 3 jaw puller to get balancer off, and use a piece of all thread and nut to install the UDP before installing balancer bolt and torqueing down.
    Real simple and plenty of room.
    Junior Member m6speed's Avatar
    Feb 2012
    wow i can't believe how people make something so easy seem so difficult. it's exactly what 98aggie says, super simple to do
    Tony -
    08 G8 GT daily modded with baby seat
    84 Grand National turbo lsx
    Beyond Help ULTRA Z's Avatar
    Philadelphia, MS
    well i will get to try this i do my cam, head, header install very soon.
    2009 SBM G8 GT
    2007 Suzuki GSX-R 1000
    Sugar Land Texas
    30 minutes to 1 hr depending on skill level and tool selection.
    Having had my ass kicked by this, I can definitively say you must have the right tools for this!!!!!
