Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: CTS-V / Vaporworx Controller install
    Boardman, Ohio
    Default CTS-V / Vaporworx Controller install
    Here are some pictures from my install to help others. I would have written a DIY but i'm not good with words
    Lonnies pump removed
    CTS-V pump installed
    Vaporworx controller mounted on top of the subwoofer amplifier bracket
    V pump plumbed into the stock system with a single braided line
    G8 metal fuel feed line will need to be straightened slightly
    Harness routing to the battery and control module
    VIP Member blue-mayhem's Avatar
    Huntsville, Tx
    Looks good Greg... Hope to get my pump by this weekend so I can put mine in too!!!
    Boardman, Ohio
    You should see it tomorrow
    PM sent
    Oct 2011
    Greg,
    Thanks for the photos.
    Now that you have a chance to install the kit and drive the car, what else does the kit need, not need, performance expectations, etc. Without feedback it's hard to make the kits better.
    Boardman, Ohio
    I don't think the kit needs much. I had plenty of wire, misc bolts and connectors. It was easy for me because I have done some wiring in the past on cars and my mother worked for Delphi so I had some cimp tools in my tool box to get everything the way I wanted
    Maybe include a few zip ties. I picked up a bag from Harbor Freight cheap so it wasn't an issue.
    The real feed back will come from the other guys getting ready to do the installs soon. That way I will know everything was included
    I can tell you I love just being able to hit the key and have the car start instead of having to remember to give it a few seconds to prime, and now I can also put my spare wheel into the trunk instead of the FPR.
    The performance testing won't come until the roads get warmer and my stock size tires can handle the +200 over stock horsepower.
    So far so good Carl A+
    Member TMorgan800's Avatar
    SoCal
    Nice writeup! Thanks Greg!
    2009 Panther Black G8 GT, TVS 1900 @ 10lbs, RotoFab, Injector Dynamics ID850's, Squash "Big Single" Fuel Pump, Kooks 1 7/8" Black Cat Coated, Solo Perf. 3" Exhaust, 20" Camaro Replicas, Pedders and Whiteline bits all over
    Huntsville, Tx
    I'm the same as Greg... I don't feel like explaining everything, but here is a couple more pictures of the PWM CTS-V fuel system that might help you out...
    Make sure you disconnect your battery and drain all the pressure out of your fuel system...
    Make sure your fuel tank is below 1/2 or you will have a mess!!!
    This is the G8 fuel level sensor hooked into the CTS-V pump it will just snap right in, but you will need to bend the rod down a little bit to get the tank to read correctly... My was only off by about a 1/8th. You will also have to use the terminal ends that Carl provides you in the kit to get the wires to hold in the connector that plugs into the bottom of the pump.
    Here is the CTS-V pump and PWM kit all hooked up.
    Look at post 169 for more help with hooking up the PWM Controller.
    http://forum.grrrr8.net/showthread.php?t=29359&page=17
    Huntsville, Tx
    Updated my post with some pictures... Thanks Greg, Carl and also Pete for all the research.
    Oct 2011
    Did you get a chance to fire up the system?
    Huntsville, Tx
    Quote Originally Posted by Carl@Vaporworx View Post
    Yes I have and it's holding up to the abuse!!!
