Results 1 to 10 of 20
Thread: ZL1 Pump Kit
    Boardman, Ohio
    Default ZL1 Pump Kit
    Edit : New kit available See below.
    You can install a ZL1 fuel pump into the G8 for added fuel volume.
    We offer a ZL1 kit that includes:
    ZL1 fuel pump module
    Jet pump crossover tube
    Lower PSI fuel pressure regulator
    Secondary fuel level sender and connector.
    Current price is going to be $360.95 plus shipping.
    You will then need to contact Carl @ Vaporworx for a fuel pump power connector and ZL1 fuel pressure regulator adapter. (around $40.00 for the parts)
    This method will require dropping the fuel tank to install the secondary fuel sender and new crossover tube.
    This kit is not on our site yet so PM or Email me if you are interested.
    -Greg
    EDIT
    EDIT
    Now available is a complete ZL1/1LE fuel pump upgrade kit.
    GMP-19260557
    This kit includes a brand new ZL1 fuel pump module, fuel level sender, 58 psi regulator, and the Vaporworx adapter kit (pigtail connector, regulator adapter, and crossover tube adapter)
    Or if you already have the pump module and regulator from we also over the Vaporworx kit separate under part number G8ZL1MKIT
    Feb 2009
    Oxford,Pa
    not that I'd be buying one but how much can it support
    Boardman, Ohio
    Shane is using this pump for over 600 with his BAP running.
    I would say 500 to 550 maybe.
    VIP Member Kermit's Avatar
    Va. Beach, VA
    What is the difference between this and the CTS-v kit that your putting in your GXP?
    2009 G8 GT MGM.
    VIP Member Daniel Linnett's Avatar
    Oct 2010
    ArklaTex
    greg can you not cut access on both sides instead of dropping the tank? I already have my solution just wondering for others out there who may go the zl1 route
  6. Likes Arcangel2479 liked this post
  7. #6
    Boardman, Ohio
    I don't see why you couldn't cut two access holes instead of dropping the tank.
    The difference between this one and the and the CTS-V version that is in my GXP and in a few other cars very soon is this is a single 255lph pump and the V pump is a dual 190lph pump (I think) that must be powered by a PWM controller.
    The V kit is a better all around option than the ZL1 pump but the cost is a little over double that of this system.
  8. #7
    Friendswood, TX
    -Greg
    Greg .....did I get "everthing" i need from for you this install? (minus the pump itself)..............?
  9. #8
    Jul 2013
    What is the purpose of replacing the level sender on the secondary pump? Is it incompatible with the sender that comes on the zl1 pump? I assume the G8 secondary level sender will not play nice with the ZL1 primary level sender?
  10. #9
    Boardman, Ohio
    The reason was so there was not any cutting needed to the stock crossover tube. I'm in talks with Carl to sell an adapter piece to mate the G8 crossover tube to the ZL1 pump. This will eliminate the need to "create" an adapter like everyone has done up until now.
  11. #10
    Jul 2013
    Oh. Ok thanks for clearing that up. So you can just install the zl1 pump and wiring if you can adapt the crossover tube to the smaller zl1 nipple.
