I received my parts today from Greg. I plan on doing a rather technical review of the parts that came as a kit.
I have read a few forums where some had indicated some tight bearings. I did a quick inspection of the trunions and the bearings.
The trunion bearing surface diameter was approx .0004" difference in size over the 16 pieces. The bearing case was closer at approx .0012" difference.
I also checked the center hole location to see how close it was too center. The farthest piece was .008" off center.
The biggest difference was the spot face for the bolt. I had one that was .014" deeper that the next deepest one.
Monday, I'm going to take a couple to my customers and see how round the bearing surface is. When I was using the micrometer to measure the diameter I can tell some had quite a bit of ovality.
When I put my kit together, I'll be doing a selective fit, to make sure all pieces have as close to the same press as possible.
I also noticed that one piece has a small nick. The packaging for this kit could be much better.
I'll get some pics up this weekend. I also bought a 1 ton arbor press for the job.
