Transmission Cooler Parts Ordered!
Updated insight: Updates/Thoughts here
Here is what I ordered today... should be a blast!
B&M 70273 15,000btu Stacked Plate Cooler 11"x5.75"x1.5"
-6an hose ends
3/8npt to -6an for cooler
10ft stainless hose -6an
Assembly Lube, Thread Sealant
Am going to grab the line at the quick disconnect at front of the block or at the bottom of the radiator. Hopefully it all comes together, making the investment of better hose, ends, and cooler worth it!
Think I'll need about a quart of extra fluid?
how much did it all cost?
what is the advantage of doing it this way rather than buying the oem GXP transmission cooler kit from pace? is it just total BTU?
lvgmman
More BTU, personal learning experience, quality fittings and look. Mostly just cause I love to learn new things and figured I could put together a kit for the same or less money that performed better.
About 175 total, all fittings, stainless hoses, etc. Can't wait to install it.
that seems like a small cooler. Any reason why you chose the smaller one? I normally use the 70266
Got the cooler in... mounted it below the bumper... those that have done it, has anyone done it that way? The top two mounting holes are bolted to the front of the bumper plate, the bottom holes sit just above the plastic pan at the bottom of the radiator.
Get Some
Lets see some pics, this is on my list to do.
Atmospheric Acquisition
Pictures
So how did you end up routing the lines?
When i did mine one lines runs to the line in front of the motor/drivers side one. and the other connection goes into the drivers side of the radiator.
Get Some
shane
Did you use the radiator as a pre-cooler? Do you know all the part numbers for the fitting you used to adapt the trans lines and radiator port to AN?
Pictures
Pics...
Used split fuel hose zip tied at 4" increments to secure and hide the ss hoses behind the kidney.
Hoses protected with split loom and tape, ran through factory holes in bumper.
Lines ran, protected along same path as heat exchanger lines, passenger side of radiator.
Lines connected...
The only thing I don't like about it is that its not in any direct airflow besides probably the bottom left corner through the lower grill. I hate to say it, but if I was going to do it again, because of the Maggie heat exchanger and needing to keep the washer reservoir, I probably mount it above the crash bar inline with the kidneys and call it a day.
