Results 11 to 20 of 43
Thread: Transmission Cooler Parts Ordered!
    Looked at it again... actually the majority of the cooler is in airflow line because of the foglight grill. Isn't close enough to the radiator to have the fan really pulling air through it, but at speed should immediately drop. Refill and testing my fittings here in a bit.
    Whose dumbass idea was it to put the washer reservoir there?
    And I do wish I had ordered 90deg fittings for the an lines at the cooler.
    Oh well, as long as it works, I'm good.
    Lake Jackson, Tx
    Part numbers for the quick connect adapters?
    STL
    Quote Originally Posted by hartigan85 View Post
    Did you use the radiator as a pre-cooler? Do you know all the part numbers for the fitting you used to adapt the trans lines and radiator port to AN?
    My fittings were from PCMforless.
    Jan 2011
    I have mine sitting right behind the passenger side kidney grill and there's no problem with air flow there thats for sure.
    Lucky SOB G8GT721's Avatar
    MA
    I was thinking of putting it behind the fans. Anyone know which fan operates first/the most?
    2008 White Hot G8 GT
    SLOWHAWK Tuned
    My Garage
    MA
    Bump
    Anyone?
    SLOWHAWK Tuned
    My Garage
    Quote Originally Posted by G8GT721 View Post
    Bump
    Anyone?
    How are you going to secure it?
    MA
    Depending on how strong it is, standoff the fan shroud or brackets off the frame. Not sure yet just an idea right now
    SLOWHAWK Tuned
    My Garage
  9. #19
    What are "normal" non cooler trans temps? Fully warmed up?
  10. #20
    Jan 2011
    I would think normal would be in the range of 90-100C maybe 80-100C. I can tell you this the trans goes to limp mode once it hits around 240F.
