Results 1 to 10 of 14
Thread: Maggie Belt Slip: Jannetty Racing Magnuson Belt Tensioner
    Friendswood, TX
    Default Maggie Belt Slip: Jannetty Racing Magnuson Belt Tensioner
    Developed for the Camaro....but wouldn't it work on our G8's?
    http://www.gettorq.com/store/chevrol...0-2011-ss.html
    VIP Member 08G8V8's Avatar
    Savannah, GA
    I believe Daniel has a HD belt tensioner, but not sure of the brand. I think it's made by East Coast Superchargers.
    Boardman, Ohio
    You would need one for a Corvette not a Camaro to have a chance of working.
    VIP Member Daniel Linnett's Avatar
    Oct 2010
    ArklaTex
    yes I have the East Coast Supercharging one
    Friendswood, TX
    Quote Originally Posted by Daniel Linnett View Post
    Hey Daniel!! Is that unit working "well" for you? No slip? The design of both units (Jannetty & ECS) look awfully similar.....
    The East Coast unit is a bit less expensive as well.
    Oct 2010
    ArklaTex
    What pulley do you want to run, there is a point if you are OD cog and small on the front that nothing you will do will prevent slip as enough of the belt does not wrap the front pulley.
    Friendswood, TX
    3.0
    Oct 2010
    ArklaTex
    you will be fine with 3.0 and HD tensioner
    now if you cog drive/OD rear and OD front 3.0 is as far as you will probably make it.
    Jun 2016
    St.Louis
    witch East Coast Superchargers tensioner are you using?
    Too Loud, Too Fast, Too Damn Bad!!!
    TX
    First, complement you for using search, instead of slamming you for bringing up an old thread! Second, I think Daniel sold his car three years ago, not sure if he comes around here anymore.
