Page 1 of 8 123 ... LastLast
Results 1 to 10 of 76
Thread: Everything you wanted to know about the G8 diff and half shafts
    Default Everything you wanted to know about the G8 diff and half shafts
    Ok guys, I've tore down the new G8 rear assembly I got and I must say. GM did a much better job on the G8 then they did on the GTO.
    First off the half shaft dia is about the same as the GTO but the inner stub axle is much larger as can be seen compared to the GTO inner stub.
    They also used a speed sensor in the hub instead of a reluctor ring on the inner stub (big improvement)
    The inner axle stubs are the same length on both sides, everything is the same from side to side except the axle shaft (bar) length.
    One axle shaft is about an inch longer on one side.
    The outer cv joint retains the axle by a snap ring (a hard pull will pop it right out)
    The inner cv joint has a large snap ring retaining the cv assembly into it's housing and then another snap ring keeping it on the axle. (remove the large snap ring, pull the cv assembly apart and then remove the axle snap ring to get the axle out)
    The axles are 37 spline with a 1.18 dia at the splines.
    I'll add more information here when I get the diff tore down to see what makes it tick.
    Here is why you have the problem with the inner stubs popping out.
    You can see the very small machined landing that the retaining ring has to catch on.
    The retaiining ring area can be seen in this photo on the end of the stub.
    The Camaro center section is a direct bolt in for the G8.
    It bolts up perfect, same width and also uses the same inner stubs.
    So all you would have to do is find a Camaro center section and bolt it in.
    Gforce Engineering
    LIFETIME WARRANTY!
    The Leaders in IRS Drivetrain Technology
    gforce1320@gmail.com
    www.Gforce1320.com 316-260-8433
    http://i25.photobucket.com/albums/c9...honenumber.jpg
    The axle shafts are pretty much the same diameter as the GTO but the G8 axle shafts are 37 spline, a big improvement.
    And the pinion gear is huge. It's considerably larger than the 9 inch ford pinion gear, looks pretty strong.
    Gforce Engineering
    LIFETIME WARRANTY!
    In the middle of NC
    Very good info! I'm sure a lot of guys will be happy to hear that. Do you think it will hold up to ~500 rwhp ok?
    - John Henry Boetcker
    I'll know more when I get the posi tore down. I had to stop for the day.
    Gforce Engineering
    LIFETIME WARRANTY!
    Addicted Member Cobra's Avatar
    Keizer Oregon
    Tease! Get back to work
    Clarks Summit, Pa.
    I will say this, there don't seem to be many Aussies breaking these.
    They've had 6Ms since the beginning, too.
    Plastic Cuttin' Bad Ass!
    Moderator GM_Fan's Avatar
    Indiana
    Quote Originally Posted by Cobra View Post
    +1 more info..
    Thanks for sharing what you have so far.
    Central Florida
    Agreed. My biggest priority is the easiest and cheapest way to get 3.27s.
    Clarks Summit, Pa.
    I've been thinking about this again.
    I think our best bet (cheapest) is to wait for 3.27s to be available through GM parts. With the arrival of the GXP, there are going to be gears in the parts system, it's just a matter of time.
    Central Florida
    Maybe so. I'm gonna see what the blower does for me, if that's not enough I'll be poking hard at this again.
